Horsetan
LNER P2 2-8-2
Re: Atlantic's works inc. RTRconversions. Mystery coaching s
Post by Horsetan »
mlgilbert30 wrote:. ....something that I only noticed late last night on the tender. Can you spot it? In all honesty its not that easy on the one photo showing the whole tender....
[/quote]
No toolboxes / cabinets on the front bulkhead?
A short aside, if I may be permitted? Graeme was among a group of us visiting Little Bytham yesterday and he brought some of his stock along to show their paces. Among the little gems I photographed:
Original W1.
ECJS luggage brake from a Dan Pinnock kit.
I have a film of his C1 thrashing through LB with 13 on which I have now uploaded here. Others I am unable to post here at the moment.
I have failed my mission. I cannot spot the omission from GN's tender. Does the loco have cab doors by the way?
Regarding faults on tenders, since my own stupidity finally dawned on me, and I made a post-photographic correction to the added fittings on my resin streamlined non-corridor model, I've been waiting for somebody to point out that I had posed one of the fire-iron brackets on the front of the tender at a strange angle as if it were instead some sort of handle or lever :oops:
45609
Post by 45609 »
Atlantic 3279 wrote:I have failed my mission. I cannot spot the omission from GN's tender. Does the loco have cab doors by the way?
It's not easy to spot so I'll tell you. The lower row of lamp irons are missing off the rear running plate. I just forgot and it is a silly omission considering that I took the time to fill the holes and half etch in the rear of the DJH brass tender body.
Cab doors? Yes eventually. For now I have agreed with the client that they will go on once the tender connection has been shortened by the required amount. Some road trials are needed first.
Horsetan
LNER P2 2-8-2
Post by Horsetan »
A box containing a Jamieson V2 went into the post today :P
I shall await the postman with baited breath....
mlgilbert30 wrote:The lower row of lamp irons are missing off the rear running plate.
As any fool could have seen using his "looking round corners" vision?
strang steel wrote:the only way for 3rd class passengers in compartments 2 and 4 to exit onto the platform would be to go into the corridor and then out through an adjacent compartment. This might cause a little light panic in the travelling public.
A silly arrangement one might think, but Howlden GN designs and Howlden inspired ECJS designs seem in a number of cases to have included either dummy doors just to make a coach side "look right", or no external doors at all to some of the third class compartments (or third seating bays in semi-opens), restricting access to/from platforms if not on the corridor side of the coach.
Blimey, we're on page 199.
Horsetan
LNER P2 2-8-2
Post by Horsetan »
Atlantic 3279 wrote:I shall await the postman with baited breath....
Best you use mouthwash first, 'cos you'll need to sign for the parcel.
45609
Post by 45609 »
Looking round corners? I did say it wasn't easy. I'll keep that ability a closely guarded secret along with my invisibility cloak
Nice video of the C1 in action too. I'm envious that you boys have been out playing trains again.
LNER4479
Post by LNER4479 »
jwealleans wrote:Among the little gems I photographed:
Original W1.
I thought the original W1 was painted battleship grey and had a high pressure water tube boiler...?
Great video - with commentary too!(!)
45609
Post by 45609 »
Back of tender now sorted out. Missing coupling hook also dealt with.
Tom F
Post by Tom F »
Stunning work Morgan.... I'm not letting it tempt me back to post war! ;)
Tom Foster
davidwest
Post by davidwest »
Looking good to me!
Nice rear end (oo er missus).
LNER4479 wrote:
jwealleans wrote:Original W1.
Maybe that is "original" in the way that a responibility-shirking politician might claim to have meant it?
Can you name the chief commentator, in one?
LNER4479
Post by LNER4479 »
Atlantic 3279 wrote: Can you name the chief commentator, in one?
Yup!
Actually (and I'm open to correction here) what I had in mind was that it was the first of the conversions which has spawned all these resin based and increasingly ugly variants.
Morgan, that new haircut really suits you.
