LNER clipped buffers, was there a reason??
- NBR D34 4-4-0 'Glen'
After looking at the Gresley coaches at the NYMR today a couple of questions popped up;
1) Was there a purpose for the clipped buffers?
Was it just a Gresley 'thing' so he was different from the rest of the 'Big 4' or did they have a purpose?
2) Why wern't locomotives given clipped buffers?
Karl
Karl
NYMR Guard
'Clipped' buffers have part of the edge of the buffer removed, so instead of a round shape they are flat along an edge, as below:
http://www.well-hill.demon.co.uk/lnerca ... CF0003.htm
(From the very interesting LNERCA site which is always worth a visit)
I have to say I don't know why they were used on coaches. On CCTs with end doors, they were used so that a flap door could be opened down onto them and vehicles driven/moved along a train from wagon to wagon. On coaches, I don't believe it's coincidence that they are below the level of the bodywork, but I find it very hard to see a scenario where the buffer is retracted to such an extent that it passes under the body.
IIRC earlier Gresley coach buffers were clipped top and bottom; later ones only at the top.
Non-corridor coaches had round buffers.
I thought I had read that somewhere but had not seen any proof of it in action apart from on our resident Thompson CL, which I thought may have had replacement buffers as IIRC it was built in BR days and not actually LNER days.jwealleans wrote: Non-corridor coaches had round buffers.
Karl
NYMR Guard
David Jenkinson hints at an answer in his British Railway Carriages in the 20th Century.
Longer carriages needed larger buffers because they could be prone to buffer locking on curves when marshalled with short wheelbase stock.
Some railways adopted oval buffers. If you think about it, it is quite difficult to turn a full size oval buffer on a lathe, but it is much easier to make a large round one and clip off the top (and the bottom). Why clip them? Could it be that large buffers were unsightly and got in the way of the corridors if they extended above solebar height? They were also heavier.
These Gresley corridor carriages also had buckeye couplings which rendered buffers unnecessary and so these were retracted to allow the buckeyes to keep the carriages apart. Continuous rakes of Gresley Corridor carriages should be modelled with retracted buffers and these are available. When I fitted mine with Kadees, I also fitted retracted buffers so that I could use a Kadee with a shorter shank. The carriages at the ends of rakes should have extended buffers.
Colombo
Colombo
- richard
These are the N Gauge ones from Chivers. "RC906 N Gauge LNER Extra Long CCT".
I was sorting out last night and found the instructions and noticed it said to file them - something I missed when I was making them. I also see on the diagram (the same one as is in Historic Carriage Drawings vol.3) that the tops are shorter.
