Some of you may have seen a discussion on RMWeb about these characterful vans which I've often looked at as a potential scratchbuild.
A chap from the GNSRA has commissioned a set of CAD masters, initially for his own HO layout but also available scaled up to 4mm. I have requested a set and will report in due course. They are only a sides and ends resin casting but that takes a lot of the legwork out of building something. Mick is looking into buffers and axleboxes, I believe. Available diagrams are:
14s 8 ton with wooden underframe
15S 10 ton with steel underframe
later 15S with steel underframe and end with louvres and drop panel
16S 10 ton with wooden underframe and end with louvres and drop panel.
The built examples above have been made up using proprietary underframes. To be more accurate the headstock was channel with the buffers mounted on wood packers, the spring trunnions are very distinctive and the steel and wooden underframed bodies had slight differences. Photos in Tatlow, on the Cheona LNER wagons book and in a booklet available from the GNSRA.
These castings are available though http://www.chrisjward.co.uk/ although there is no information on there at present. I'm awaiting confirmation of the price although I'm advised it is 'in the region of £10'.
PM me for further information if this doesn't answer any queries.
GNSR Outside Framed vans
Re: GNSR Outside Framed vans
I thought it was familiar. A check has revealed I have a very old built Ian Kirk kit of the same van. The underframe on this doesnt match the photo in Tatlow either.
A search of the usual supplier drew a blank on suitable parts for the Van so a bit of a none starter for me.
In the pictures the cross bracing looks much to deep. In the Tatlow photo and on the Kirk version it is much more shallow.
