60007 Sir Nigel Gresley
Bryan
Post by Bryan »
Apparently it has just passed its boiler hydraulic exam.
So its on its way back to steam.
Re: 60007 Sir Nigel Gresley
Post by 60800 »
I'm confused as to why 60007 needed a boiler hydraulic exam. As far as I understood it on my last visit (in October 2011), the problem was with the cheap chinese copper used to repair the firebox and the boiler was fine.
Blink Bonny
Post by Blink Bonny »
Blackout, the boiler and firebox are regarded as one unit for inspection and insurance purposes. Hence the need for a boiler inspection after firebox surgery.
Believe me, you don't want to be anywhere near a firebox that springs a leak under pressure. And the firebox is the "weak link" in the boiler.
Yes, I saw Roger Barker in the newsagent on Wednesday teatime and he was very pleased about it.
Post by 60800 »
One more small query, are the boiler and firebox still in the frames, or have they been removed for the tests?
They'd have been removed for the work and wouldn't be put back until tested. I did ask Roger if he'd put it back - after all, he'd had all afternoon - but he said (I think) March.
60044
Post by 60044 »
The boiler/firebox hasn't been out of the frames. The work was done with it in situ.
Was the work inside the firebox, then?
Post by 60800 »
I presume so, as when I saw her back in October, everything in the cab was gone and a few panels (access hatches etc) had been removed from the streamlined casing too.
