Hi All,
My attempts at building a garden railway. It was something I mentioned to Richard a while back and have finally got around to doing something about it. I hope my efforts may spur others on to attempt a garden layout - so much fun (and hard work!!) and it certainly is an exercise in civil engineering in miniature!
I have decided that this simple piece - an embankment with a road under tunnel - would be a good intro into creating one of the many cameo scenes to be placed around the railway. I have now got to a couple of years or so down the line(!?) into building the railway (interspersed with building a 5" ground level line in and out of the O Gauge) and a lot of ground work has been done before I got here.
The tunnel is made in modular construction, cast in concrete as one would with resin or similar materials (see the piccies) and made from some simple moulds, knocked together one Sunday and cast one evening. They were demolded and weathered in a couple of hours one afternoon, a few of days later. They were then checked for fit with a "dry" assembly and finally cemented into place a day later.
The road and embankment had been built about a year earlier and as you can see, I'm just waiting for the undergrowth to grow around the tunnel to finish the scene off.
You may notice the baseboard above the tunnel, looking slightly the worst for wear - this is one of the last few sections that has to be replaced and properly covered - but that's another story - and a job for this summer (if the weather ever drys sufficiently) when the tracks over the tunnel will become four instead of two.
I have also been constructing the start of a viaduct to approach the rockery section over the last couple of weeks and will post some pics on here when the weather eases off and I can get to finish the cementing of the pieces into place - hopefully later this week. Like the tunnel, the pieces are all cast in concrete and weathered with cement dyes. More later.
Regards,
GeoffB
Building a Garden Railway in O Gauge
- NER J27 0-6-0
- Attachments
- Just like the real thing, the stone work looks darker and more sombre in the wet - the viaducts are even more so.
- (220.29 KiB) Downloaded 390 times
- Finally cemnted into place at the top of the road. Now we've just got to sit and watch the scenery grow round it!!
- (182.88 KiB) Downloaded 420 times
- Dry run to check everything prior to cementing in situ
- Road_Tunnel_Dry_Assembly.jpg (128.41 KiB) Viewed 5419 times
- These are the components after demolding and weathering with cement dyes. These actually lighten as they dry, unlike paint.
- Road_Tunnel_Compnts_web.jpg (108.54 KiB) Viewed 5419 times
- richard
Yes they look good. I like the weathered millstone grit look - lots of bridges like that around Leeds, and of course up in the Pennines.
I tried it with some plastic bridge sections and paint, but couldn't get it to work, but I probably gave up too quickly (moving house/etc).
I guess the cement dyes work a bit like the pigments that Woodland Scenics sell? These soak into plaster rock, and it is then sealed with dilute PVA glue (you'd need to use a different sealer for outside of course - perhaps a polyurethane 'wash' would do the trick?). They're fairly easy to use - I used them on my Wyoming module to get a weathered reddish/yellowish sandstone outcrop look.
- NER J27 0-6-0
Hi Richard,
The beauty of the cement dyes is that they do wash in with water and once they have "gone off" and the concrete is a few days old, they stay in the cement and don't need a sealer.
I do the weathering while the cement/concrete is still "green" and since I use a polymer in the mix it has to be done within a few hours of demolding, otherwise the concrete is sealed.
When I cement the units together, I let the cement go off for about an hour (using quick setting/frost proofing and waterproofing additives in the mix) and then add the dyes by gently rubbing them into the damp surface and the carefully grooving the surface to match the stonework, thus hiding the joint.
If the weather holds off a little I will get some pics of the viaducts on this weekend.
Regards,
GB
Regards,
GB
- Bullhead
Very attractive - and the dwarf/alpine type plants you've chosen enhance it, too. Just don't be tempted to model this:
- Attachments
- Weedkilling train, ex-LMS stock, Dumbarton 1986
- (97.5 KiB) Downloaded 365 times
