Golden Eagle from Minitrix A4
- f4kphantom
- LNER Thompson L1 2-6-4T
This thing was a labour of love to get the whole lot to fit together and get it to WORK. I removed alll of the original handrails and double chimney from a Mallard body and tender which had seen good use. Fitting the Langley single chimney was straightforward but not the valances, I understand now why the kit is for the Farish version, the valve gear protrudes a lot less on the Fairsh models. I used Railmatch Doncaster Green and Fox Lining which went on great. It's the 3rd model I've done, I think it looks OK, it certainly runs OK. If anyone is interested, I got the curve for the ogee by scanning the decals and transferring the line onto masking tape.
The next one to come will be Capercaillie, saves changing the chimney!
- Attachments
- (125.15 KiB) Downloaded 216 times
A couple of questions if I may...
Nice model.
I'm about to do something similar, producing a Silver A4 from the Farish model . Is the whistle from the original Minitrix, part of the Langley kit, or something else? It looks better than the Farish version.
Have you used Fox Transfers for the lettering and numbers? I ask because there is no trace of carrier film that I've always associated with waterslide transfers.
- f4kphantom
Thanks for the compliments.
The whistle is the original Minitrix part.
The numbers and letters are Fox decals. I applied gloss varnish to the model after painting and then after applying the decals I used satin finish. The joining pieces between the letters LNER were cut out.
I have since heard about a method which works just as well and is cheap as well, paint the model with two coats of Johnson Klear, apply decals and finish off with two more coats. For those who have not come across before, Klear is an acrylic floor finishing product. It dries with a perfectly smooth finish when applied by brush or spray.
- f4kphantom
The skirts weren't bad at all, a bit of filing was needed at the cab end and to fit the curve of the running plate. I attached them with Araldite Rapid. Removing the moulded handrails and the double chimney took a lot longer. I have one of the Farish ones to do and the valve gear fits a lot better, the Minitrix ones need a bit of modification to get it all to fit but the valances hide a 1000 sins
- silver fox
I had/still have the skirts, and couldn't get them right for love not money, were they fitted to the underside, or outside?
I have the incorrect Mallard in LNER Blue (un skirted)
and in BR (late)
2 x Unions
Merlin and
Falcon
but don't fancy painting them
I'm after Silver Fox next, when I can find it at a reasonable price.
(Well it's the York show next week, I'll see what's there!)
and in BR (late)
2 x Unions
Merlin and
Falcon
- silver fox
Been doing my first name change (ok so no name yet!)
Been doing my first identity change, of UoSA to Dominion of Canada
- silver fox
I've had a good look round, and I can't find the wings anywhere, but still have the other bits in the box, the only thing is the single chimney, I found the double, but didn't get a single, I'll see them tomorrow at the show, so will find one with a single chimney.
I fancy building a Silver, due to the easierness of on lining round the curve!
- f4kphantom
- silver fox
Went to the langley stand, but they don't have the a4 kits on the shelf, and you have to ask, and with no one bothering me, I stalked LH Loveless, and ended up with a Silver Fox, coming Tuesday to the door, and the first coaches he's doing? 7 Car Silver Jubilee to match Silver Fox
As for Nagauge, it was either pathetic, or the best stuff had gone! All I could muster were Merlin in BR Late (Again!) and Knight of (THE) Thistle in BR Late, I had intended a couple of A4s and a couple of BR 04s.
Nether mind, I did come back with also RTCS 2A, and a DVD on the A4s in Scotland...oh and some new track cutters after I broke mine cutting a nail (a big one not track one!)
And TV's own Harry Gration didn't buy a program, but he still got to Leeds to do the evening news!
And while I'm on, Lawrie Loveless, was posing the question of Mallard. On 'that' run, which set of coaches did it run with? All I have been able to find out is that it was 6 of an 8 car set.
- silver fox
Digging up an old post, while I'm on the subject!
Has any one had any problems with Farish A4s/Pacifics navigating points? Mine seem to go fine for a few laps, then the front bogey jumps the point and derails!
Richard, did you find a fix for the front bogie? I'm looking at getting some of the N Brass kits for my locos as it really does improve the look of the model. Why didn't Farish fit scale wheels on their models until now?
Mark, I cut and filed my A4 valances from a piece of nickle silve, took about 20 minutes to do and another 30 minutes to fit to the loco so that they didn't foul on the valve gear.
