Does anyone have a drawing of the external ventilator covers on the doors of Gresley LNER coaches.
I’m building kits (KAlasercraft) of 51’6” ordinary stock, the ventilators at the top of the doors are flat rectangles of laser cut wood. Looking at photos I wonder if the covers are angled outwards slightly from top to bottom and have curved edges on the top and sides.
The kits are gauge 1 10mm/ft so the detail is very noticeable.
Many thanks
Ralph
Gresley door ventilator cover
Re: Gresley door ventilator cover
These might help.
- sawdust
Yes they do taper slightly towards the top, I can't remember exactly by how much but would guess about an 1/8" to a 1/4" at full size but these aren't something I've ever had to make.
Sawdust.
Sawdust.
- Dave
Ralphw,
Following on from Mikes photos and sawdusts comments you might find these extracts from drawing 12077D of help.
I can also provide the internal louvre as well if you require it.
Brilliant, many thanks for the information.
I had assumed they were metal and painted, not wood.
Given the shape I will plan to make a master and cast then in resin.
Ralph
Ralph
- sawdust
Why not do as I would if I had to make a batch of these full size?
Plane and sand a length of suitable timber to the right profile, cut them off to length, round the ends then file the vent in the back.
Sawdust.
Sawdust.
