The NBR Class G locomotives were introduced by Drummond. The first two were purchased in 1882 from Neilson & Co, to their standard design. Originally purchased for dock shunting, they proved to be eminently suitable for light shunting in both docks and the Scottish lowlands. A total of 38 were built, with the last being built in 1899.
Although the term "pug" was used for different engines on different railways (eg. the Caledonian men called all tank engines "pugs"), the NBR reserved the name "pug" for these engines. Typically, the Y9s were driven by youngest drivers and firemen. However, senior men would also be posted on the Y9s for health reasons, or as a form of demotion for misdemeanors on the mainline. Apparently more than one driver known for speeding, ended up spending a number of years shunting Y9s at Leith Docks!
Rebuilding with new boilers started in 1913. Nos. 308, 343, and 344 were withdrawn in 1921/2, and had not been rebuilt. Five had not been rebuilt by Grouping: No. 1103 was withdrawn in 1923, whilst the other four were rebuilt in 1923. At Grouping, the LNER classified them as Class Y9.
No. 10087 was withdrawn in 1938, and the remaining 33 survived until 1953. These were withdrawn between 1953 and 1962.
The Y9s were renumbered many times during their life with the NBR, and received preliminary numbers from the LNER, before being given 9000 series numbers in 1924.
The new boilers fitted between 1913 and 1923 had similar dimensions to the originals, but the safety valves were located under the dome. The only other major change with these rebuilds, was the replacement of the leading coupling rod ends with a solid-bushed pattern.
The Y9s were fitted with dumb buffers. Originally these were solid wood, but were eventually replaced with a metal framework covered with plate. However, the wooden buffer beams were kept.
Due to the small size of the coal bunkers (18cwt), various 4-wheeled wooden coal carriers were used as tenders. When used, these were connected with a conventional three-link coupling. For main-line running, two safety chains were added. In 1939, No. 9308 had its rear buffers removed, and a central drawgear added, so making the tender a permanent fixture. In 1944, Nos. 9011, 9063, 9144, 9146, and 10083, also had central drawgear fitted.
68099 Permanently attached to wooden tender St Margarets shed August 1955 Drummond Y9
https://railway-photography.smugmug.com ... /i-dX3KH4q
Dugald Drummond Y9 'pugs' Neilson & Co. design for NBR - Railway-Photography
68095 Bathgate 29th March 1964 now preserved
https://railway-photography.smugmug.com ... /i-rhngfmV
68095 Unknown location
https://railway-photography.smugmug.com ... /i-GDbmCQz
68095 St Margarets shed
https://railway-photography.smugmug.com ... /i-nFZPVV5
8101 Neilson & Co. design for NBR LNER Class Y9 0-4-0ST
https://railway-photography.smugmug.com ... /i-XcfSjJd
68098
https://railway-photography.smugmug.com ... /i-cNFNKPB
68101 Dunfermline 12th July 1961 Drummond Y9 'pugs' Neilson & Co. design for NBR
https://railway-photography.smugmug.com ... /i-xzX8qq5
68102 St Margarets shed 9th February 1957
https://railway-photography.smugmug.com ... /i-tDq9mcj
68104 Kipps shed 4th August 1963
https://railway-photography.smugmug.com ... /i-tNQ52kn
Neil
Drummond Y9 'pugs'
