Micks 4mm LNER Models
Re: Micks 4mm LNER Models
Bachmann chassis never seen one of the new ones running. Where do you source them from ?
S.A.C. Martin
Post by S.A.C. Martin »
mick b wrote:Bachmann chassis never seen one of the new ones running. Where do you source them from ?
eBay mostly. I have been able to get a few for around £50 each. Given the £3 Mallard models I procured, the costs overall have remained still lower than the Railroad A4s and Hornby's main range. It is getting more difficult to get them however.
I have never seen any I presume buy it now pages ?
Parts :shock: everything is getting harder to source and more expensive. Not as much as a new C1 however :D :o :roll: :shock:
S.A.C. Martin
mick b wrote:I have never seen any I presume buy it now pages ?
Always!
First up a fictional Shark Ballast Brake. As far as I can tell the actual LNER Version has never been made a kit ?.
Conversion of Hornby Kingfisher to post war Merlin.
S.A.C. Martin
Looks good Mick. Never seen this version of Merlin before.
One of two V2's on the go this is 3/4 done awaits sand fillers, then varnish,glazing and other detail parts.
Tom F
Post by Tom F »
mick b wrote:One of two V2's on the go this is 3/4 done awaits sand fillers, then varnish,glazing and other detail parts.
Looking very nice Mick. It's a shame Bachmann didn't bother to line the wheels on the V2. I think I read somewhere the V2 wheels are not the correct size. I presume otherwise it would have been easy enough to substitute with A2 wheels.
Tom Foster
Its a big shame they didn't do a huge amount more to the V2 as well as lining the wheels :shock: :shock:
The wheels are correct @ 24mm as to whether they could be changed with the A2 I won't be finding out . The Locos are Jim's and the other reason is the A2 is done in Darlington Green by Bachmann not Doncaster Green as the V2 :D
cheers
113 needing a bit more work.
2002EarlMarischal
Post by 2002EarlMarischal »
Mick, you'll have produced more Pacifics than the LNER soon!
Great stuff as always!
A couple of A4's to do , then some proper kits B15 , F8 and a J27 :D
cheers
First of Jim's V2 done.
A1/1 body nearly ready for primer.
