Rob's 7mm Rolling Stock Workbench
- Robpulham
Re: 7mm Rolling Stock Builds - D&S GCR CCT
I made a little more progress on the fish truck last Wednesday and Thursday evenings. First I made up the brake shoes strangely there are eight brakes each consisting of a centre shoe with arm and then twelve etched outer shoes - four short to add one each side. Initially I decided to add one to each shoe and a second to the four shoes that would fit at each end. Having done this I noticed that the shape of the scrap etch that the shoes came out of would allow me to add a plain inner one to the four inner shoes with a bit of filing to shape.
I also realised that there were no brake yokes included in the kit - luckily my spares drawer yielded some nice cast ones from Laurie Griffin.
The middle shoe has the supplied etch both sides, the right hand one shows the plain one made from etch waste and the left one shows the same but with a semi circle scored in to represent the edge of the shoe itself - I am not sure whether it will survive painting but for the few seconds it took to do there is nothing lost of it disappears.
Lastly I made up the side door runners.
- Robpulham
In between work on the fish truck the Avery tool van has been progressing through the paint shop.
The CCT has also had some paint too, but it isn't quite as advanced due to one of the pipes dropping off and needing to be resoldered........
- Robpulham
Although the metal construction has slowed over the last couple of weeks I have managed to crack on with painting plus making and adding transfers.
A second parkside NBR 8 ton van is in primer and the CCT just needs a few bit's touching up and it's ready for transfers too.
Then I finally got around to printing the "return to Kirkcaldy" transfers for the floor cloth wagon. They were printed onto white transfer paper and to achieve this I scanned the wagon side to get the grey for the background and then added the lettering. It's not come out a perfect match but once the wagon side and the transfer is toned down a little by some weathering I think that they will look the part.
- Robpulham
A session yesterday morning saw the last of the transfers on the Avery Tool van and some glazing installed - I used microscope slides for this - one slide cut in half did one side.
Lastly a not very successful attempt to show the glazing in place.
I think that both the Avery Van and the lino wagon should have an 'N' on the ends of the buffer beams to signify that they are not common user wagons.
Website: http://www.mousa.biz
Did you find any more pictures of the lino wagon, Rob?
- Robpulham
Thanks again Bill, that makes perfect sense, if only I had some......sense that is, I do have N's which I can and will apply.Bill Bedford wrote:I think that both the Avery Van and the lino wagon should have an 'N' on the ends of the buffer beams to signify that they are not common user wagons.
Sadly not, all the photos I have of them are in NBR days - in fact thinking about it they might all be the same photo/wagon.jwealleans wrote:Did you find any more pictures of the lino wagon, Rob?
- Robpulham
While I had the paint on the go I decided to see what I could with these:
They are Skytrex resin that I picked up from their bits and pieces bin for £1 per strip, I do wish that I had bought more now because they don't seem to have them on their site.
I am quite pleased with how they have turned out - they were photographed in this morning's bright sunshine but they are quite subtle in reality.
- Robpulham
I have been inspired by some of the conversions of Parkside kits to other diagrams being carried out by Jim Snowdon on RMweb and the Guild forum. At Telford this year I swapped some Parkside GWR kits for some Slaters MR kits. Two of them being for the 8 ton van.
While up north over the New Year I had a look through the Essery book on Midland Wagons and although there isn't a photo to go on I decided to have a go at a conversion to a sliding roof door version.
By good fortune the spares box yielded a couple of spare roof struts for LNER cattle wagons which saved me having to mess about curving the guides for the door although I did have to curve a piece of sheet for the door itself - this I did by rubbing the curved end of a Swan Morton knife handle across it.
The kit itself is one of the quite old (in small grey box) versions that had buffer shanks moulded into the ends. This actually means that the mouldings themselves are very crisp when compared to the second kit which is in a new red box. The 'castings' for the door furniture are moulded plastic too but to be honest they are equal to the brass castings that I have for the second kit.
I managed to get a coat of primer on it this morning so here it is.
I have left the roof loose until I finish painting the inside.
- Robpulham
The Midland van has now been through the paint shop, I have weathered it using the many photos in Essery's Midland wagons book (vol 1).
Looking at them, almost all the photos in pre 1937 livery show that they got pretty grubby in service. I just need to make up and blacken the couplings and it's finished.
- Robpulham
Amongst my Telford swaps was a Slaters Kit for a Midland 4 wheeled brake van. I made up the basic model a few weeks ago but I didn't have any rod to hand for the many handrails that these vans were festooned with. So a bit of forward planning at the weekend saw me take some up north with me just in case the mood took me to fit them.
I managed to not only fit the hand rails I added further details from plasticard
The very prominent brake column and crank plus the tablet racks - these were in the spares box from an earlier build of the 6 wheeled van but I had to chop them up and add some micro strip to make them match the photo a bit better.
I added some missing parts to the end brackets which were also missing.
And heaven forbid I have become a rivet counter.......
Next I added a representation of the brake gear - it will be dark down there once it's covered in gunge.
And finally I added the blanked off panel that is visible on the open end of some vans.
My recent successes with plasticard have given me a bit more confidence to have a go at scratch building a whole wagon in plastic at some point.
- Robpulham
Having been pleased with the look of the Skytrex barrels that I did earlier ver Christmas I took advantage of a Skytrex special offer and bought some wagon loads. These consisted of two different loads of barrels - from a choice of three or four, a load of sacks and a couple of loads of carboy's (demi-john type jars) packed in straw.
In between other jobs I have painted a couple of them.
- Robpulham
A pleasant surprise when checking my remaining leave - 10 days left when I thought that I had only 2 meant that I took three days leave this week. We took a chance and went up to Bishop Auckland for a few days and having had a nice trip out on Wednesday morning we got back at lunchtime and within 10 minutes of getting in the house a blizzard started that left us with upwards of 4" of snow by Thursday morning. It was very pleasant to sit at the bech and do some modelling while the weather did it's worst outside.
First up I put the transfers on the Midland 10 ton Brake van using one of the two photo's in Essery's Midland wagons tomes.
Next up is glazing and then weathering - this will be another that is well towards the end of it's life.....
- Robpulham
This kit (Slaters LMS 7 Plank Loco Coal Wagon) was another of my swaps with a gent at Telford. It was one of the older kits in the grey narrow boxes and when I got it home and had a look the brass etches were missing (compensated W Irons/brake levers etc.) By pure chance a meet up with Graham Beare (of this and other parishes) on the Saturday evening saw me presented with an Exactoscale underframe to try under some cattle wagons that I am building (very slowly). It wasn't suitable for the cattle wagons it being either too deep or not deep enough, I can't remember now. Graham being the kind soul that he is told me to keep it anyway in case it came in for something else and it did immediately.
Having rather enjoyed the bit's of details that I added to the brake van I decided to attempt to add the interior details that Slaters don't include in the the kits. There is only one photo of these wagons in the Essery's LMS Wagons volume 1 which is photographed at the end of it's life when condemned. That said the text does refer the reader to wagons of similar diagrams which looked the same externally. One of these is a photo of a wagon involved in an accident which by good fortune gives a view of the strapping inside.
I started by using an Olfa compass cutter to measure and mark out where the planking lines were on the inside. Once marked these were deepened using an Olfa cutter to cut the grooves proper.
Then a few happy hours were spent cutting and drilling various strips of plastikard and gluing them to the wagon sides and ends before assembly. Once they were glued to the insides I drilled through into the wagon side and then inserted short lengths of plastic rod and allowed them to dry thoroughly before sanding them back to stubs.
Flushed with the success of this I then decided to add the steel strip around the top of the wagon using a similar technique but on the top I cut the plastic rod of flush to give the impression of a countersunk screw. To this I then added the capping retaining clips seen on wagons - I again once glued in place I drilled the wagon sides and inserted short lengths of plastic rod before finally assembling the sides and ends.
- Robpulham
The final installment of the build of this wagon. The underframe details are a bit Heinz 57
The W Irons and V hangers are Exactoscale
The Axle boxes and Brake levers are Parkside
The brakes, guards and lever guard are from the kit.
The door banger is scrap etch from Parkside couplings
The extension timbers and bottom door levers are MMP detailing kit.
I also added some representations of the bottom doors to the underside to cover the exposed Exactoscale underframe - not that you can see it in the photos or when it's on it wheels.....
