Tom F
Re: 2750 (Tom's) Workbench-North Eastern Modelling 1938/1950
Post by Tom F »
JASd17 wrote:It is very brave to use black and white photos of that era to judge colour, it depends on the film stock, unlikely to be known.
Is there anything in the Gresley Observer on this topic?
Not a lot of help, apologies Tom.
RCTS 2A has been the best source, but only mentions red backs on the special A4s (Original 4, Coronation and West Riding locos). But I've found 1938 colour footage of Kingfisher from 1938 with red backed plates.
This photos of Herring Gull from 1939
https://www.flickr.com/photos/swift-val ... 2769148804
And the B&W 1938 photo of Herring Gull shows very light background colour to the plates. Good enough evidence for me. :)
Where I have no photo reference, I still with black.
Tom Foster
scottiedog
Post by scottiedog »
Don't forget that Tom's at the Ormesby Hall Show, Middlesbrough, tomorrow and Sunday, with his weathering demonstration. Extra chairs are being organised for in front of his display. No pressure there, then, Tom!
Ha,Ha- only joking, are am I ?
See you on Saturday, after tea and cakes.
davidwest
Post by davidwest »
I'd like to see your work up close Tom. But itiz a bit far -enjoy though
Clock O' the North
Post by Clock O' the North »
Hello
Those models are looking real good. May I ask what you used to weather the locos
Thanks Lachlan
Modelling Preserved LNER line in the NER Region
Tom F
Post by Tom F »
Home from my first weathering demonstration and rather shattered!
It was an enjoyable meeting new and familiar faces.
Managed to get the next Gresley A1 for Thirsk LNER, 1938 renumbered (2568 'Sceptre' of York Shed).
Roll on Thirsk Show on 27th July. :)
Tom Foster
Tom F
Post by Tom F »
Couple of new photographs:
Herring Gull
Although I've shown photographs of her before, after looking at photographs, I've altered the nameplate to red backed.
Gadwall
Due to the weather, these are the first outdoor photographs of her. Both locos are in Summer 1938 condition, so both are depicted as less than a year old.
Tom Foster
Tom F
Post by Tom F »
Another of the doomed A4.
Tom Foster
Tom F
Post by Tom F »
Some more info posted regarding 'Project Thirsk' on Modellers United this evening.
http://www.modellersunited.co.uk/planni ... 49-50.html
Including a rather interesting looking signal!
Tom Foster
Post by 60800 »
A slight drift from topic, but looking at various photos, I'm stumped as to when exactly the drain cock arrangement changed from four outer and two center to six outer. I've modified those supplied by Hornby on my 2509 and 4489, with the latter being in circa 2014 / early 1938 condition. I haven't joined up the cuts simply due to the need to run on 2nd radius curves / turnouts;
Tom F
Post by Tom F »
60800 wrote:A slight drift from topic, but looking at various photos, I'm stumped as to when exactly the drain cock arrangement changed from four outer and two center to six outer. I've modified those supplied by Hornby on my 2509 and 4489, with the latter being in circa 2014 / early 1938 condition. I haven't joined up the cuts simply due to the need to run on 2nd radius curves / turnouts;
Yes, I've been aware about this for some time....but to be honest, if a drain cock arrangement is the only fault someone can find with my locos....life's not too bad! :)
Seen as my pacifics will be doing a scale speed of 65-75mph....it wont be noticeable.
Tom Foster
To be correct they would also have to stretch and be fixed to the front guard irons . havent checked dates the A4 had three drains I believe in BR times? when they were cut back at the same time as the outer guards were removed.
giner
Post by giner »
Of interest then, on page 4 of the Great Gathering thread there's a photo of Mallard and Dominion of Canada side by side with Mallard having three pipes and D of C having two pipes, as in 60800's photo.
viewtopic.php?f=2&t=8899&hilit=Gathering&start=45
Tom F
Post by Tom F »
Very enjoyable day once again playing trains on Little Bytham. Tony has kindly helped me re gauge a mass of wagons bought from RMweb member 'Scottiedog' from EM to OO (some may say that is sacrilege!)
I brought a couple of my recently weathered LNER Pacifics (destined for my future layout of Thirsk). For some reason Gadwall didn't wish to run with it's tender (creating a short) but ran fine loco only. One wonders if this A4 knew its future fate in 1942, and felt it best to not move at all! Tony did the kindest thing he could for the old bird and cut the connection to the tender pick ups. As Tony said, this is a bit like trying to cure gout by cutting one's leg off..... however it did cure the problem!
I asked Tony if he could pose the locos in the positions below, and I'm really pleased with the results. Thanks Tony!
Tom Foster
Looking very nice. Perfect combination of modelled location, period and stock. I see that you have been amassing teak stock.
Did Gadwall run at home? Is it all "one loco" or is it from a mixture of sources? Just wondering if you've ended up with opposite polarity loco and tender underframes.......
Tom F
Post by Tom F »
Atlantic 3279 wrote: Did Gadwall run at home? Is it all "one loco" or is it from a mixture of sources? Just wondering if you've ended up with opposite polarity loco and tender underframes.......
Gadwall had only been tested previously with a battery on the wheels when cleaning...as it's a recent one it hadn't run at Grantham before hand.
It is indeed a mixture of sources.... Kingfisher from trainpack with a Mallard Non Corridor Tender. It baffled all of us, as the loco was happy running on it's own, but shorted whenever any tender was attached to it.
Tom Foster
