Great Northern Bridge Plate?
I have in my possession a cast iron (?) plate measuring approx 9" x 5". Can anyone identify it..
Thanks in advance
Thanks in advance
Re: Great Northern Bridge Plate?
I'm not sure its a bridge plate, they usually looked like the example attached, which is also bigger - 17" x 13"
- Attachments
- 194.jpg (5.67 KiB) Viewed 8140 times
Got It!
Its a GNR Level crossing number plate.
- Attachments
- 486.jpg (1.92 KiB) Viewed 8140 times
Thank you Redrock! Mystery solved, the change of colour didn't help!
Just curious.
Does this plate relate to a specific level crossing and is it still possible to identify which one?
Thanks
Andy
Thanks
Andy
If anyone has any info as to what route would have been classed as GNR G4 then it should be possible to work out from a line diagram.
There again with it being a high number then a long distance route would be probable.
How many crossings are the between Kings Cross and Doncaster?
A few, I think. There was one at Arlesey and another at nearby Three Counties, IIRC. I can't recall any south of that, though.
- StevieG
Not sure of GNR practice, but in view of records used in BR days (could well've had LNER or earlier, origins), it might be said that 'there are crossings, and crossings'.
Except for (at least) station barrow crossings, all were accorded numbers - not only roads, but also, e.g occupation, accommodation, bridleway and footpath crossings.
The furthest south ECML one listed that I can recall now, was the footpath across the line at Hawkshead, not far south of Brookmans Park station.
I could be wrong but the G.N.R. bridge plates that i vaguely recall seeing back in the late 1960s & early 1970s south of Peterborough towards Kings Cross were slightly oval in shape and had a double-border around them with the letters G N R positioned inside the double-border at the top of the plate, most of them by then had been painted white/grey with the letters G N R, the double-border & bridge number picked out in black paint .
In BR days the furthest north crossing in England was No203 at Marshall Meadows At that time it had minature red/green lights
But that would have been an NER crossing and probably numbered from Newcastle, York or Shaftholme.
It's a culvert plate.
