First P2 Pic from Hornby
Saint Johnstoun
Re: First P2 Pic from Hornby
Post by Saint Johnstoun »
Studied the test shot at Perth MRE yesterday and they have got the boiler cladding right (eliptical or egg shaped above the boiler centre line!)
I'm now even encouraged to believe that the upper sides of the boiler may have the correct shape as seen from above, viz:
Saint Johnstoun
Moving on to 2003 etc. a close study of these shows that the boiler cladding is not parallel along the top of the boiler so it would not be possible to do an easy modification of 2001 to a bugatti front.
Now for that I may have a cunning plan, not involving a turnip.
Post by 60800 »
If you change your mind Graeme, I know a cunning fox who can get you a turnip shaped like a thingy.
Back (and forth) to sanity, did anyone get a good look at the bearings, contacts and drawbar?
drmditch
Post by drmditch »
Saint Johnstoun wrote:Moving on to 2003 etc. a close study of these shows that the boiler cladding is not parallel along the top of the boiler so it would not be possible to do an easy modification of 2001 to a bugatti front.
Are not Hornby considering producing a model with the streamlined front end anyway?
(Although hopefully they won't do so until I've got some more money!)
drmditch
Post by drmditch »
Sorry, don't know how the duplicate got posted
65447
Post by 65447 »
I shall not bother to post duplicate replies 8) but 'informed sources' have previously indicated that all members of the class will eventually be produced...
Post by 60800 »
Right, just need to wait to put my order in for 2002 with streamlined nose then ;)
Saint Johnstoun
On trying to draw SK on the subject on Saturday last at the Perth MRE the answer was if the first model sold well then other members of the class would be produced. The chassis has been designed to allow for this.
Kestrel
NER C7 4-4-2
Post by Kestrel »
Hattons reckon the P2 is due on or after Monday 23rd December 2013.
AJ427
GNR J52 0-6-0T
Post by AJ427 »
Wow, only just seen this. Impressive. I was resolutely not going to buy one since I can in no way justify it. Now I'm not so sure.
AJ in Bradford
My Ivatt N1 3d printed models available here http://www.shapeways.com/shops/AJModels
My Great Hotton Blog (Bradford-Queensbury Lines 50s) https://ajmodels.wordpress.com/
jukebox
Post by jukebox »
Saint Johnstoun wrote:On trying to draw SK on the subject on Saturday last at the Perth MRE the answer was if the first model sold well then other members of the class would be produced. The chassis has been designed to allow for this.
If SK did mention the chassis that way, you should have chipped in asking if it also converts to a 4-6-2... :shock:
K160
GNR J52 0-6-0T
Post by K160 »
The sample looks pretty good. Will have to find room for this on the loco roster.
Matthew Davis
will5210
Post by will5210 »
Will
viewtopic.php?f=3&t=9293
My Blog
