can you help me identify LNER carriages please
wehf100
Post by wehf100 »
Hi all,
I am trying to make sure I know the diagram numbers of the following three carriages. Location is Immingham Dock Station. Photo undated, but taken early 1950s. Loco is a K1.
Left to right I think they are
Non-gangwayed 4 compartment Brake Third (diag. 64 or 65- depending when it was built. Identifying feature is lack of guard duckets)
Ex-GN Corridor Brake (diag ?)
Non-Gangwayed 8 compartment Gresley steel-sided Third (diag. 276) ??? Or is it a Thompson?
Have I got these right? The middle coach has me stumped. It looks a little short to be a LNER period carriage- is it ex GNR perhaps?
cheers,
Will
Re: can you help me identify LNER carriages please
I think you're right about the GN one - the giveaway is usually the small window above the door rather than a vent as on the LNER ones. The GN did build some 52'6" stock as well, so without the benefit of a diagram bok to hand I'd go with that.
2512silverfox
Post by 2512silverfox »
Middle vehicle is a GN 61' 6" BCK - not sure which diagram - I will have a look tomorrow.
2512silverfox
Further to last night's post. The GN vehicle is a 58' 6" BCK (2X1st; 4X3rd) to Diagram 175 - one of six vehicles.
wehf100
Post by wehf100 »
Nice one Silverfox! Rare vehicle then. Thanks for checking this for me.
Out of curiosity- do you think this carriage would still have been a BCK when it was photographed in the 50s or instead downgraded to all third class accomodation?
Finally, does anyone know of a company that provides a model for this carriage in 4mm scale? Closest I can find is Mr. Bedford who makes a diag.176 BCK- similar enough?
regds,
Will
wehf100
Post by wehf100 »
p.s.
Anyone want to comment on my provisional identification of the steel suburban? I have guess this is a Gresley rather than Thompson vehicle because i) it appears to have square window frames rather than rounded and ii) a Thompson would only be a couple of years old at this point and unlikely to have been running on such a backwater line?
Any opinions welcome.
Will
IAK
Post by IAK »
wehf100 wrote:p.s.
Will
Well it makes sense to me Will. Ones reasoning has good grounding.
It is mind, a wonderful image of the mixed up rakes that appeared in those early BR days
sawdust
Post by sawdust »
If the third were a Thompson, I think the different body profile would stand out.
Sawdust.
2512silverfox
Re the GN BCK: My diagram book does not give any downgrading and it was updated until the late 50s including the change to 8' 6" Spencer Bogies. Given that the train otherwise had no first or lavatory accomodation, it would make sense that it remained a BCK, as most of the BCK did.
Kemilway offer it in 4 and 7mm.
wehf100
Post by wehf100 »
cheers guys,
Will
UpDistant
Post by UpDistant »
Will
Sorry about the delayed reply - I'm busy trawling through topics in a variety of forums (fora) to see if I can offer some help.
The third coach is a Gresley. The steel sided ones are much easier to pick out in a train of mixed Gresley/Thompson stock when you compare the depth of the underframe trusses - Thompsons are deeper i.e. nearer the rail head. The brake compartments of the steel Gresleys are also inset as in the teak stock whereas the Thompsons are flush.
Was the loco really a K1? AFAIK they all ran with GS type 4 - (welded) 4200 gal tenders.
UpDistant
52D
Post by 52D »
Up distant ive just noticed the tender then your comment its probably a K3.
60129 GUY MANNERING
Post by 60129 GUY MANNERING »
52D wrote:Up distant ive just noticed the tender then your comment its probably a K3.
I was thinking K2/2 as soon as I saw the Photograph! :o :o
65447
Post by 65447 »
UpDistant wrote:Will
UpDistant
Apart from the lower angle trusses and flush Van ends, the Thompson carriages also have the bottom window line lower, being fitted with taller windows, and a lot of them had the rounded corner windows too.
