This may as well serve discussion about the original Clearwater TV series made in 1984 and initially narrated by a certain Beatle. Whether or not others know, the first two series did stick well to Awdry's initial books, then drifted away as the series went on.
To explain a small inconsistency brought up elsewhere by Wootang:
As you may remember in the original books, Thomas wasn't thought nor drawn until the following book. In place, there were two unnamed tender engines who were in the shed, along with the ostensibly bigger Gordon, Henry, and one that looked like James but wasn't. As to explain the TV series error, there is no real explanation - it is a simple goof along with the likely decision not to waste a large sum of $$$ making models for two unfeatured engines who wouldn't appear again.but in the first story (EDWARDS DAY OUT) as a TV episode i quote
"all the other engine were bigger than him and boasted about it"
since when was the tank engine number one bigger than edward?
Anyone else want to share their memories (or knowledge) of the series?
