Micks 4mm LNER Models
- 2002EarlMarischal
Re: LNER Models
That has to be the first time I have seen that line-up ever! One that even Barrow Hill or the NRM won't be able to stage! Great achievement Mick!
Lovely, interesting, different models, great setting - something to aspire to!
Thanks for posting the pics! Superb!
Re: LNER Models
Wonderful work on the 'Wolf', and the lineup has got to unique,brilliant
- Tom F
Re: LNER Models
Ah yes Tim did mention had been admiring her....glad to know all is well with her....I'm sending Tim the etched deflectors tomorrowjwealleans wrote:I believe I had it in my hands on Saturday and pretty good it looks too.I have word my Herringbone is in a it's final stages
Lovely line up Mick...I'll be doing the same in a couple of months on Leaman Road
Tom Foster
- 60800
Re: LNER Models
Quite an enviable line up of pacifics you have there
- 60800
Re: LNER Models
Pictures etc now moved to my new workbench thread
- Tom F
Re: LNER Models
I don't mean to appear rude blackout, but this is Mick's thread for showing his work. I'd suggest setting your own up.
Tom Foster
- 60800
Re: LNER Models
apologies, I mistakenly took this as a thread for anyone to post things about LNER models. I'll set up a new thread for Mallard ASAP
EDIT: errr, I've sorta forgotten how to relocate posts
or delete them for that matter. Can't seem to find an option for it
Re: LNER Models
I was wondering
click the edit button bottom right to clear your text
Re: LNER Models
Another A2/2 Lord President is on the workbench.
I will post some pictures not covered in the build of The Wolf.
A4 Cab mated to A2 body using the original A2 footplate to ensure all mates correctly. Photo after being left overnight for plastic cement to cure. The cab was held in place with masking tape during the cure. Gaps between cab and boiler in picture have now been filled with microstrip pieces prior to rubbing down and smoothing in due course . Tender body repainted to LNER Apple Green. Other pictures below show how I have adapted the Hornby chassis so that the Bachmann tender connector can still be used. Microstrip and a 8BA Bolt nut and washers have produced a nice strong connecting pin.
There is no need for the Hornby tender connector ,as loco runs fine with the Loco pick ups only, as supplied by Bachmann.
- 2002EarlMarischal
Re: LNER Models
I confess I have a vested interest in this one but it's great to see some different shots on this build Mick. Coming on really well already! Thanks for posting!
- 2002EarlMarischal
Re: LNER Models
Actually, I meant to say that I've been going back through your thread Mick, and Helensdale provides a superb backdrop for your models. It's full of interest and looks so life-like. I'm sure that if you half-close your eyes and come down to baseboard level, you could almost be there!
I'd be really interested to know the dimensions of the layout and see a track plan if you have one in a suitable format?
Re: LNER Models
Loving it Mick - both in apple green I suspect!
I'm going to pluck up the courage to order parts from Graeme next pay cheque, my only concern is how I get a hold of a decent A4 cab and the tender body. Is the A2 tender body suitable, albeit with the rivets removed? Or is there an easier way?
Re: LNER Models
E Bay personally.
I am not aware of any retail stockists of the current high detail Hornby or Bachmann bodies/tenders.
I personally prefer the Hornby version as its already the streamlined version and is a excellent model in its own right.
The A2 is one the another non corridor versions, at a minimum you would have to remove all the rivets and build the front up.
Re: LNER Models
quote="2002EarlMarischal"
I'd be really interested to know the dimensions of the layout and see a track plan if you have one in a suitable format?[/quote]
Nowhere as big as I would like its 10ft x 8ft . I will post a trackplan in due course
