Actually, Coachmann, 46229 ran in BR Green for its last weekend of boiler ticket over at the East Lancs and I couldn't get there for it! Fume!! Rant!!!! Apparently it was paid for by an organisation along the lines of Sentimental Journeys.coachmann wrote:Trouble is it's been done, though not on a Duchess maybe. Funnily enough, a BR green Duchess has never been run in preservation, and considering it was the longest lasting livery for the class and that BR green had been applied to many other locos, this is a first.Owzabout BR blue, Coachmann?
With vineals now availabe for just about anything one can dream up, I feel now is the time to dress a rake of Mk. I's up in grained teak livery. No lining as this would look plain silly. such a rake would look better behind the LNER liveried mainline locos than all the other liveries put together.....which they often are!!!
A4 4492, NYMR Autumn Steam Gala
- Blink Bonny
Re: A4 4492, NYMR Autumn Steam Gala
- 60800
One thing I was meaning to ask and now I have the opportunity to with the picture of Green Arrow in apple green is her wheels. Why are they black? Is it weathering from barely three years of work or were they left black from her repaint?
- Blink Bonny
Ay up, Blackout
I was actually suggesting to Coachmann that an LMS "Duchess" be painted BR blue. I have Graham Farish N Gauge one and very impressive it looks too!
Although thinking about it......
..... should make a few folk spit out their dentures! Could look good....
I'm certain that the appearance in that photo is a trick of muck and shadow. The cleaned but not repaired Green Arrow that I saw in Shildon in May '09 had green wheels, although the "black" frames and underside of running plate were rough and grey, presumably the consequence of exposure to grit, grime and weather.blackout60800 wrote:Green Arrow in apple green is her wheels. Why are they black?
I like the idea. We'd then see what Eastern Region might have done to its prestige trains had it been allowed the same sort of reassertion of group identity that allowed LMR to turn out Crimson Pacifics, WR its chocolate and cream coaches and green humble mixed-traffic engines, and the oceans of green coaches on Southern Region. So long as somebody doesn't see vinyls as a means of dodging the expense of proper rust removal and basic painting of the metal surface!coachmann wrote: I feel now is the time to dress a rake of Mk. I's up in grained teak livery.
Any idea how much it would cost to print and apply ersatz teak vinyl wrap to a coach????
If the teak is too much of a challenge, I quite like tourist livery as a second choice.
- 60800
I've seen Green Arrow four times since her boiler certificate ran out, once at Shildon, three times at York and I must admit I didn't take a blind bit of notice of the wheels, I was too busy being overwhelmed at the sight of her (I get VERY emotional around Green Arrow). I have to admit I even cried when I saw her at Shildon for the first time in two and a half years Always was bleedin hard to catch that V2 anywhere, regardless of a boiler certificate or not!
Get your hankie out again. Green Arrow, Shildon May 2009. Note the generally near-black oil and muck on the wheel, but Green showing on the balance weight, and through the muck around the white-lined black axle-end.
- Blink Bonny
How nice to see evidence of hard work on an engine likely to be stuffed and mounted for the rest of its days.
Unless we could persuade Mr Waterman to spend a ton of money on it?
- 60800
If only he did.
Atlantic 3279, I would get my hankie out if I had one, but I'm afraid I'm a bit too young for that, teenagers don't usually cry y'know
I've heard rumours that 60009 Union Of South Africa (my second favouirte loco) is to be stuffed and mounted at Shildon when her next boiler certificate runs out from this current overhaul This can't be true can it?
Dream on! Pete Waterman isn't particularly interested in the LNER (although I'm told he does have a bit of a liking for Thompson coaches..... Hasn't put any money into the sole example that is currently under restoration afaik, though)
- H&BR Q10 0-8-0
This the Pete Waterman who owned Scotsman? Granted, he did put it in BR Green...60044 wrote:Pete Waterman isn't particularly interested in the LNER
Could we try to get this close to the topic again, rather than the (admitedly agreeable) outrage at stuffing and mounting locos. Poor 901
Am looking foward to seeing '4492' on the 'Moors; shame it can't run into Whitby.
Moors Bound
- 60800
yep, network rail (or whoever owns the Whitby line) won't let pacifics up there because the wheels scrape on the final bend and the 9F isn't allowed because of it's flangeless wheels, which according to network rail will cause it to derail. It's the flangeless wheels which keep the bleedin thing on the curves
- H&BR Q10 0-8-0
They won't let pacifics down because of flange sraping? So why did they let Pacers down for ages? They squeal on straights! Actually, from what I heard it was the A4 preservation group, after their first run down there with 60007 that suggested that A4's shouldn't go down there.
I bet they wouldn't let the Q6 down, though I can't remember if it has any flange-less wheels...
Speaking of the Autumn Gala, I know it's rostered, but I doubt 75029 will be ready in time. I wonder what the 'Mystery Guest' could be?
Personally I hope, and hear me out here, I know it SEEMS blasphemous, but I hope it's a GWR loco of some kind. Two reasons:
1- We'd have at least one loco from each of the Big Four.
2- We can finally show people that us Northerners got loco design right!
Moors Bound
- 60800
I'd love to see a GW castle try and tackle the ascent to Goathland from Grosmont with the full Whitby set. The black fives barely manage 5mph!
I was told elsewhere that the objection to flangeless wheels these days is that somebody has decided that it is good idea to raise check rails above running rail level in certain places on the national network, so if you don't have a flange to prevent the possibility of the tread climbing onto the check rail (can the flangeless wheels really run that far across?), then the raised flangeless wheel is presumably considered capable of lifting other wheels off the rails too. Unless of course the true potential is for damage to the check rails?blackout60800 wrote:It's the flangeless wheels which keep the bleedin thing on the curves
Sorry for further digression. On the original point, I'll be glad to see a Garter Blue, fully valanced A4 and teak coaches, whether or not the parabolic lining on the A4 is a bit dodgy and the crests of the previous BR livery are evident in relief through the blue paint on tender.........
