Micks 4mm LNER Models
Re: LNER Models
No comparison with the Plastic offering
E Bay not at all the same time
Re: LNER Models
A repainted from a lurid Mauve colour Corgi Trackside Scammell, the trailer has been converted to a flat bed and glazing added to Cab , lastly Fox transfers used for lettering
Re: LNER Models
More on Brown Jack , now my Laptop has been repaired
Re: LNER Models
Next are pictures of my last of my A3's name not decided on yet, has also been started. This will be last as I have now run out of bodies and chassis to convert
This body will need far more work than the previous A3's I have converted from the NRM base body.
I am making/have made the following
Single Chimney
Handrails
Front Steps
Ash Pan Lever
Nearside Steam pipe and base
Cab Doors and Wind defectors
Lamp Irons
Vacumn Ejector Pipe hopefully just the missing section
As this body is so rough I will also add a correct Banjo Dome and reline the Boiler Bands using HMRS decals.
The cab has had one side repainted due to glue damage , the top of the boiler also need touching in due to different shape of the Banjo Dome. Luckily Hornby add the dome after painting the boiler so the marks are slight. Precision Doncaster Green is a perfect match . Tender is a Mallard version that took a nosedive of my layout a while ago hence the large repaired crack in the picture. I have cut the streamlining of the top and add beading to the sides/end to represent the version fitted to the Banjo A3's at the time of their building.
Re: LNER Models
A renumber of one of the latest BR Bachmann Wagons to a LNER version very nice . I have a couple of the NE lettered Vans arrive as well ,excellent quality.
Re: LNER Models
Nice work all round Mick, but if you are right then Hornby must have used a different paint recipe compared to the colour that is on my two China-made super-detail Flying Foxes (one renamed Roayal Lancer) as that is NOTHING like Precision or Railmatch Donny Greenmick b wrote:Precision Doncaster Green is a perfect match .
Re: LNER Models
Mick,
Nice work on the A3 there. I have had some of the new Bachmann wagons too, top quality. I thought the paint could have been a little redder but that is being very, very picky.
Where did you get the A3's from is it ebay or someother Flying Scot graveyard?
Re: LNER Models
E bay for the wrecks and the chassis's. Probably cost me about the same for the four I have built for the rrp of one mint A3 !! A good challenge to !!
These are the NRM version perhaps different paint now used ?
Re: LNER Models
Relettered , lightly weathered and fitted with Screw Couplings versions of Bachmann latest vans.
Re: LNER Models
Two detail points which Bachmann have got wrong with their LNER van liveries. The buffers and headstocks of all vehicles with steel underframes were black to match the solebars and the vac stand pipes were always painted black unless on piped vehicles when they were red.
Re: LNER Models
Thanks for info , easily rectified for once
Re: LNER Models
A couple of my A1's at rest
My current Hornby A3 rebuild is coming along nicely both Loco and tenders are repainted , new parts have nearly all been made and fitted.
Spent most of today lining the tender more pictures soon
Re: LNER Models
Great Pics. Which two are they?
Hornby made a model of A1 Gladiateur with the reversing gear on the wrong (left) side but regulator etc on the right. I was wondering if it may be an easier job to rebuild this as an A3 than to reline and repaint a BR A3. Perhaps Gladiateur is harder to come by though.
Just a thought.
Just a thought.
Re: LNER Models
They are both renamed/numbered Hornby A1 Great Northerns in early 1923 livery.
A3's are left hand drive so Gladiateur not suitable as it is modelled in A1 form even though the reversing rod is on the wrong side . Yes I never noticed on my one it will be moved across .
Re: LNER Models
Firdaussi finished. It has been rebuilt with new scratch parts . A spare A4 chassis was converterd into a A3 using new wheels ,cylinders, valve gear , catazzi truck and tender underframe.
