nzpaul
Post by nzpaul »
Jim de Griz wrote: Sat Nov 23, 2024 8:18 pm
Tim Watson wrote: Sat Nov 23, 2024 2:28 pm The chimney is actually very small at only 2mm tall.
I love watching your A2 come together, but this comment really highlights how impressive your craftmanship is. The zoomed in photos almost hide just how incredibly precise your work is!
Jim de Griz
Quite agree.
I wouldn't claim the right to speak on other's behalf but, I'd be surprised if "love watching Tim's work" isn't a universal sentiment around here.
Tim Watson
Post by Tim Watson »
The last boiler fitting for the Raven 4-6-2 class is the safety valve plinth. This is circular in plan view with three in-line valves (these will be turned from non-tarnishing metal on the model). Construction was much as the other fittings except for the SV holes. The plinth is 0.6mm high
Parting off is with a piercing saw. The spindle in the tailstock is to capture the loose component.
The 0.6mm centre hole was drilled on the lathe and the other two on the precision drill press.
The disc is far too small to hold when forming the curved under surface to fit the boiler. It was therefore held in a glued collet with super glue and the concavity filed in.
Two pins were placed in the front and rear hole whilst a slot was cut in the holder to show the orientation for grinding in the saddle.
The shoulders of the SV plinth were filed off and then refined using a fine abrasive disc.
Next job will be to mark up and drill the handrail and other holes in the boiler & smokebox.
Tim
Tim Watson
Yesterday was spent drilling out over 30 holes from 0.3mm diameter (handrail stanchions) to 1.8mm (chimney, dome & safety valves). The washout covers, studs and nuts then needed to be made before the boiler fittings could be epoxied into place as their placement would involve soft soldering.
The access covers are held down by central studs and nuts which would be represented by some 0.4mm brass wire located in pre drilled holes at the crown of the firebox: three RHS, two LHS. The covers were made from 5thou brass strip tinned with 145 deg solder and folded in a zig zag to make up six layers, sweated together and then a 0.4 mm hole drilled through the lot.
This was then filed down to size around the stud fixing hole.
After separating the covers, some 0.4mm wire was then tinned, and threaded through the cover hole and pushed into the firebox. The area was gently brought up to temperature using a small gas torch with plenty of phosphoric acid flux.
The excess wire was then trimmed off and the area cleaned up. The two holes on the top of the firebox near the cab are for the whistles, which will also be made from non tarnishing metal.
On a slightly different note, I wonder how many people recognise the source of the brass for the dome & safety valve plinth?
After making the safety valves, the next job will be to glue all the fittings in place.
Tim
Tim Watson
Turning gold is quite fun. The safety valves have now been made and fitted. Tomorrow will see the boiler fittings glued on; in daylight and with fresh eyes…
It will be nice to get the engine back up on its wheels and take a proper photograph.
Tim
Tim Watson
As promised.
Tim
Lovely work. :mrgreen:
Tim Watson
A friend at work examined the front end of the Raven 4-6-2 class yesterday, observing that it wasn’t quite level. Unfortunately, he was absolutely correct: when you make things you often see what you want to, rather than reality. A bit of tweaking was required.
Tim
Tim,
considering my modelling skills, i am loathe to criticise from the photo, it seems that the boiler is not square and parallel to the frames
at the front. The smokebox handle does not seem to be in the middle of the frames
Hopefully, it is only the photo angle, but I hope it helps
Tim Watson wrote: Wed Dec 04, 2024 7:01 pm... observing that it wasn’t quite level...
You should try life with light level variable astigmatism - well, that's near enough. Rolling past on Copenhagen Fields, marvellous!
Given that the above view can be be seen not to be straight along the dead-centre line of the loco, I'd be very hesitant to draw any judgement.
Mersey508138
Post by Mersey508138 »
I must agree, taking photographs of locomotive projects I have worked on as I progress has not been the easiest of tasks to carry out.
I have to also say that the loco hs been built to a standard far in excess of anything I am capable of and is an absolute masterpiece of skills and engineering in 2mm scale. It took me a considerable amount of time to put together a 4mm loco and tender body which I purchased off ebay a few months ago.
The loco body was half completed but the tender body was still to be assembled but after roughly 3 - 4 days of wrangling with it, aswell as a few modifications to make it fit on an rtr 0-6-0 chassis, the loco body was fitted to the chassis and can now haul 7 mk1 coaches instead of the original 2 or 3 coaches it could barely manage with it's original plastic body.
My apologies for the slight digression but that is about as far as my engineering skills go and if I had the chance, I would certainly like to improve them.
Tim Watson
In a fiddle yard, far, far away… best to play the Star Wars theme when looking at this.Image
The next project for CF. It has actually been in gestation for quite a while, collaborating with Mike Trice. Construction of the bogies actually started in August.  They are incredibly tedious to make.
Tim
P.S. I think the smoke box ‘deviation’ is a photographic effect from not being dead centre in view. The locking bar being off vertical doesn’t help either. That is currently loose and the whole assembly is bolted together, so capable of some adjustment.
Four twins and a single carriage. I wonder what that might be...?
Tim,
never one to doubt your skills, how dare I??
It is also the "lamp iron" at the top does not seem quite right either.
I am quite happy to be wrong, but if we do not strive for your standards, then why are we bothering?
Comparing the recent frontal picture of the loco with earlier ones, I am wondering whether a new black mark has already been made to indicate the top-dead-centre position for a re-drilled lamp iron or handrail knob socket.
