Aha, of course..
Nothing like a stupid question to brighten your day.
Aha, of course..
Speaking midway through my first attempt I'd have to say it is actually quite hard but more importantly, very time-consuming: prepare for the long haul...Atlantic 3279 wrote: ↑Fri Nov 12, 2021 12:22 pm Fully lined GNR two-tone livery with brown frames. How hard can it be?
Slight segue from the thread subject, it is a very happy chance that between the GNR and NER's practises, early livery styles from the dawn of the railway survived in simplified form on the LNER, both for locomotives and carriage stock, to the end of its existence.Chas Levin wrote: ↑Wed Nov 17, 2021 5:44 pm... it will look really superb in GNR colours ...Atlantic 3279 wrote: ↑Fri Nov 12, 2021 12:22 pm Fully lined GNR two-tone livery with brown frames. How hard can it be?
This is generally true of all C19th designs; not only because they are outwith living memory, save for the rare preserved item, but also I feel because until fairly recently very difficult to make into competent running models. I was so grateful that the NRM/Rapido solved the difficulties of an operable Stirling single.
I think you're confusing me with someone else here......Hello Jonathon,
Little influence on the sound, it's noisy whatever is done. I suspect the intention was to initially direct the escaping steam - and thus the condensate - upwards, to avoid 'power showering' passengers while the loco was standing at a platform.kimballthurlow wrote: ↑Thu Nov 18, 2021 1:40 am ...At this juncture I must ask too if anyone knows why these (safety valve) covers were used?...
Yes very much confused..... and confusing so my wife tells me.jwealleans wrote: ↑Thu Nov 18, 2021 9:58 amI think you're confusing me with someone else here......Hello Jonathon,
As it turned out, when I had a proper look at that other loco I realized that I had "mis-remembered" things and that there really wasn't much at all to modify in readiness for its repaint. The logic may seem strange, but that told me that I could afford to leave that one alone just for now, and that as I was really starting to want to see existing projects finished rather than yet more of them "on the go" I could therefore safely change my mind and start painting the 174 series. Hence, although this image is far from sharp, I now have, in pieces, a part painted loco and tender, with most of the twiddly bits put safe elsewhere for later re-fitting:Atlantic 3279 wrote: ↑Fri Nov 12, 2021 12:22 pm
Actually, an existing model of an LNER loco I acquired a while ago, nicely built but in most unsuitable BR mixed traffic livery, is scheduled for some minor alterations first so that I can deal with the application of mostly Doncaster green livery with the relevant lining to two locos side by side.
