Gresley coach numbers after Nationalisation
- LNER N2 0-6-2T
Hello all,
I have bought some Hornby Gresley teak coaches from Hatton's and will be repainting them to suit my 1958 period layout. Does anyone have a source for stock numbers I should use on them? e.g. EXXXXX?
Thanks,
Trevor
Thanks,
Trevor
Re: Gresley coach numbers after Nationalisation
Which models did you buy?
- LNER N2 0-6-2T
The numbers are
L.N.E.R Teak Composite (1st/3rd) Coach 22357
L.N.E.R Teak Brake Composite Coach 4237
Thanks,
Trevor
Thanks,
Trevor
Trevor
website: http://whitbywestcliff.blogspot.com
R4332 and R4333
They are the old style Hornby coaches which aren't models of anything and so you can't give them a true number. That's why people have been getting rid and buying the new ones, albeit a lot more expensive. The old style, however, are still made for the Railroad range.
have a look at viewtopic.php?f=3&t=11370
- LNER N2 0-6-2T
Thanks for the info.
Trevor
Trevor
Trevor
Trev
I've just remembered. I've got a book that lists all the Hornby there has been so I could have a look there and see what numbers they put on the blood and custard/maroon equivalent.
Phil
Phil
Right Trevor, I've found the book, Ramsey's British Model Trains CatalogueGoathingham wrote:The numbers are
Thanks,
Trevor
22357 is listed under several Hornby catalogue numbers as R435, R477, R1039, R4047, R4332 (Railroad)
their running numbers in BR red and cream are given as:-
E18276, E18299, E18301, E18236E, E18269E, E18170E, E18171E, E18281E, E18274E.
In BR maroon they are:-
E11000E, E11002E, E18207E, E11029E, E18249E, E18271E.
4237 is also listed under several Hornby catalogue numbers as R436, R478, R1039, R4333 (Railroad)
E10066, E10098, E10050E, E10051E, E10066E, E10097E.
in BR maroon they are:-
DB10074, E10058E, E10064E, E10065E, E10073E, E10076E, E10108E, E16769E.
I hope this answers your original question.
Phil
- LNER N2 0-6-2T
Thanks, Phil. Exactly what I needed.
Trevor
Trevor
Trevor
