I have copied the shed allocation of retford and so far can only work out what two of the types of loco are (B1 and O4). The other locos types I have different starting number for are 41779 (ivatt 2 I think) 58077 and 85
64188,234,321,402,759,830 and 906 and finally 69277 and 69300. I also plan to model other classes that passed or visited the shed (Retford 36E GN) Does anyone have any pictures or know where I can get more info Thanks Tom
Class of loco advise needed
- Location: Barrow in furness Cumbria/HMS Collingwood Fareham
- richard
Alas my lists are arranged by class!
So far I have J39s: 64759, 64830, 64906
64759, 64830: J39/1 and built at Darlington
64906: J39/2 and built by Beyer Peacock
It looks like the sub-class refers to the tender type.
I thought you might have some heavy freights in the list, but they look to be 63*** or were given LMR (O6) or ex-WD BR numbers (O7).
I'm guessing they're 0-6-0s - possibly ex-GCR types?
I'll post more as I find it...
Richard
Richard
Tom
You should use the Locoshed Index to get the allocation and an Ian Allan Combined Volume to get the classes. The combined volume should be easy enough to find on ebay or at a swapmeet, bookshop etc. They do reprints as well as original soiled copies.
This is the 1955 allocation.
Johnson 1F 0-6-0T: 41779
Johnson 1P 0-4-4T: 58077 58085
B1: 61126 61208 61211 61212 61213 61231
O4 and 01s: 63608 63637 63654 63655 63688 63736 63782 63785 63905 63914
O2: 63924 63925 63926 63927 63937 63945 63949 63961 63965 63970 63972 63976 63979 63980 63982 63986 63987
J6 :64188 64234 64241 64245 64252 64255
J11: 64280 64283 64287 64295 64321 64340 64341 64347
64380 64385 64393 64395 64402 64403 64416 64421 64422 64423
64451
J39: 64759 64830 64893 64898 64906 64908 64961 64970
N5: 69277 69282 69283 69300 69308 69313 69314 69321
I have underlined my cops which are mostly collected at York or Doncaster, so you can see that the B1s J39s and the O2s worked on the ECML up to York and Doncaster and the rest were probably on the GC shed.
Locoshed Index
http://www.users.globalnet.co.uk/~luigi ... 32.htm#36E
Colombo
64451
Locoshed Index
Colombo
