Well, it is over - we've finished at the George H.W. Bush Presidential Library. We (the Tex-N club) were there for the past two weekends, setup in the entrance atrium as a part of the ongoing railroad exhibition.
The library is on the campus of Texas A&M University in College Station (Texas).
The atrium was large - we fitted all our modules with room to spare. It was also the grandest place we have set up in. With a glass roof, the layout was usually lit with natural sunlight which made a big difference. We are used to gloomy artificial light in exhibition halls! With the exception of radio throttle problems on the last day, the layout ran with all but the most minor of glitches.
Lots of people were interested. Unlike shows, most of the people were members of the general public and they still expressed a lot of interest in one form or another. I think we were a hit
We also had more than the usual "little interfering fingers" problem. I'm not quite sure why. Distracted parents perhaps, although we also had to have our stanchions fairly close in a couple of places, and we were relatively short staffed on the last weekend.
My Tomix Thomas was a big hit, and continues to be a reliable runner. I can't believe how ecstatic those kids get!
The layout configuration uses the N-Trak standard, but we choose to use both Blue and Alt-Blue. This results in four through tracks on most of the modules. Rather than the usual square shape, we have a smaller loop with branches coming off it. Each branch is terminated in loop module. Two DC lines (the two blues) ran around the loop. The other two lines ran DCC and ran around one or both of the branches. We also have the mountain line implemented on four modules. This runs as a closed loop returning on the front (orange) line.
The two DCC lines typically ran multiple (2-4) trains.
Period and location is typically whatever we feel like, although most if not all club members try to get a train self-consistent (eg. no wooden box cars with a modern SD90 diesel!).
Most of my stuff ran well. I had the V2 hauling 40 wagons - mixture of heavy (loaded coal wagons, and the Dapol wagons) and lighter (most Peco and Farish). Later on yesterday, I had the same train being hauled by the J94 - which did very well. Far better than the real thing
The V2 is clearly a stronger puller than last time I tried it with <30 wagons. I haven't touched it, so I think the tender pickups might have loosened off a bit on their own (some have reported success at improving performance by loosening them).
The Americanized Flying Scotsman proves to be fragile. It runs, but would never be capable of handling conventional running condition. This was half expected - it was never a great runner before the conversion. Alas my photos of it have blur, but one of the better images is below.
With 5 days of running, it was possible to maintain and fix things whilst other trains were running. This proved useful as my J39 is now a bit quieter (free running loco axles needed lubricating), and my FRED (flashing red emergency device) now works properly - these hook on the rear car and replaced cabooses about 15-20 years ago. Yes I have one that works in N, taking power from the rails.
The actual exhibition itself was aimed at the general public. Things like displays of what each car type carries, Presidential trains (typically election trains or funeral trains), model collections (including some of Sinatra's), etc. There was a cab mockup (ie. very simple simulator) for kids, a running video of the UP 4141 naming ceremony,etc. One of the museum custodians was telling me that UP 4141 will be retired after 1 million miles and donated to the museum. This is the engine we saw up at Fort Worth a few months back. Painted in Air Force One colours, it is still remarkably clean!
Report from the Bush Presidential Library
- Attachments
- My LNER locos were not the only UK contingent at the show. The Houston Live Steamers had these engines off to one side.
- bush_livesteam.jpg (90.16 KiB) Viewed 3266 times
- The Flying Scotsman stops at the Trost Yard during its steam excursion. I had a lot of trouble with motion blur, so apologies for the state of this picture. My Wyoming module pictures were far worse - hence they're not here.
- bush_fs.jpg (35.18 KiB) Viewed 3265 times
- Here's the back of my UK module. The module is a work in progress. Although I've said that I've completed the back, it still needs more street clutter/etc. The tram needs letters/ads/etc, and the window frames need toning down as well.The tram poles are w
- bush_uk.jpg (20.61 KiB) Viewed 3263 times
- We have a large yard for setting up. Of course it looks best when it is full, but it tends to acquire an eclectic mix of trains (Amtrak, US intermodal, and LNER all feature here).
- bush_yard.jpg (58.97 KiB) Viewed 3264 times
- Vineyard module.
- (91.19 KiB) Downloaded 61 times
- A different view of the cattle scene, with an Amtrak train about to have a near-miss with the straying longhorns...
- bush_amtrak_cattle.jpg (81.56 KiB) Viewed 3264 times
- Scratch-built Santa Fe cattle dock - a new addition for this show. Note the longhorns - including some crossing the track...
- (179.68 KiB) Downloaded 61 times
- Tunnel on the same loop module. Note the effect of the natural sunlight.
- (190.75 KiB) Downloaded 61 times
- Scratch built trestle on one of our loop modules. The natural sunlight overexposes the limestone effect at the bottom (a quarry is located below the bottom of the picture).
- bush_trestle.jpg (92.11 KiB) Viewed 3264 times
- The right side of the layout.
- (101.85 KiB) Downloaded 61 times
- Overall view of the left of the layout. Gives an idea of the height of the entrance area, although the roof is quite a bit higher.
- (114.35 KiB) Downloaded 63 times
- Bullhead
Spookily, I was listening to Wilko Johnson's cover of "The Western Plains" when I looked at your picture of the Longhorn cattle crossing the river. I've always had a soft spot for American prototypes, and would one day like very much to see a "Big Boy" (there's a South African metre-gauge Garrett at Summerlee Heritage Park in Coatbridge, but it's a pale imitation - and it has a tree growing out of the boiler cladding).
But I still can't bring myself to use the words "President" and "Bush" in the same. Sentence.
So - did anyone dare tell Stephenson, "It's not Rocket science"?
This is Daddy Bush (Bush 41 as they say around here)
It seems like all the recent presidents have had presidential libraries, and here in the US a president usually gets a certain level of respect regardless of politics (Nixon being an exception - and history has yet to decide about Bush 43).
They're currently deciding on a location for the Bush 43 library. The Missus's Univ. is in the last three in the running. She finds herself torn on whether this is a good thing or not.
(the University of Dallas has the best/most logical proposal, and it would raise the Univ's profile, but...)
Back to trains... We have a Big Boy here in Dallas. I've even stood in its cab. There's also a Mikado with a booster (like those that Gresley experimented with), a GG1, and a DD40X (DoDo using UK diesel classifications). Unfortunately they're all stored outside, and only a diesel switcher is in running condition.
None of the club members have a model Big Boy. I think (but could be wrong) that they've only been offered in N in brass. We do have some Challengers and Mallets. Most club members run diesels though.
The Mallet that was running this weekend, was a real smooth runner - very tempting, if they're available as Rock Island or Texas & Pacific
- Bullhead
I'm reminded of the story that when RAF pilots who had been used to the Spitfire converted to the P-47 Thunderbolt, they reckoned that they could dodge hostile bullets by running around in the cockpit...richard wrote:We have a Big Boy here in Dallas. I've even stood in its cab.
The club site now has pictures from the recent Wills Point and Bush Library gigs:
http://www.tex-n.org/TrainShows/TrainShows.html
