Just a question regarding Finsbury Park no.4 circa late 1960s and early 1970s and the Up fast line colour light home signal?.
If the Finsbury Park no.4 signalman had accepted a train on the Up fast line from Finsbury Park no.6 at the north end of the station but the block section between Finsbury Park no.4 & Holloway North Up and from the summer of 1970 after Holloway North Up was abolished and Finsbury Park no.4 was then working with Holloway South Up on the Up lines and if after accepting a train on the Up fast line from Finsbury Park no.6 the signalman in Finsbury Park no.4 'pulls off' his Up fast line colour light home signal that was located off the south end of the Up fast line platform beyond the Seven Sisters road bridge with the Finsbury Park no.4 Up fast line starting signal still standing at danger would this colour light signal immediately clear to a 'yellow aspect' or was it 'approach controlled' and would only clear to a 'yellow aspect' when a train was approaching it along the Up fast line after passing Finsbury Park no.6 and was possibly midway through the station before this Finsbury Park no.4 colour light home signal would clear to a yellow aspect?.
Finsbury Park no.4
Finsbury Park no.4
- thesignalman
Re: Finsbury Park no.4
It is possible it would clear to yellow if the lever was operated, but trains should have been checked at it by the signalman, as it was still a semaphore signalling area in principle. The only circumstance when it could be cleared when the starter could not be would be when that starter was acting like an Intermediate Block Home and had its own overlap track circuit to prove the line was clear for 440 yards beyond it (just like block signalling acceptance).
"BX there, boy!"
- StevieG
Unusually in my opinion, for track-circuited through platformed stations in the area Mickey, the Up fast TC'g at Fins. Pk. was split, a little more than halfway through I'd say.
IIRC, only the first TC was indicated in No.6 Box, and only the second was indicated in No.4.
I don't know in detail about the operation of No.4's UF Home (lever 2 IIRC) from R-->Y, but it would make sense if, after accepting an UF train, and while the Starter (lever 1) was to remain at Danger, the No.4 signalman could have Reversed lever 2 at any time but the Home remained at Danger, only stepping up to Y when the second TC in the platform became occupied, (or of course the Starter was cleared, allowing the Home to Clear straight to green).
Thanks John & Stevie because for some reason I started thinking about that colour light signal the other evening that was worked by Finsbury Park no.4 and wondered if it would 'clear' straight to a yellow aspect with the Finsbury Park no.4 semaphore starting signal still standing at danger or would some sort of 'approach control' would have been fitted to that signal so as to have reduced the speed of an approaching train travelling along the Up fast line due to the Finsbury Park no.4 starting signal standing a danger and being located on a shallow right-hand curve?. From memory that colour light signal had a x3 aspect colour light head that could show either R/Y/G as far as I can remember. Also from memory that particular colour light signal worked by Finsbury Park no.4 and located beyond the south end of the Up fast line platform at Finsbury Park could be 'read through' by approaching trains travelling along the Up fast line before reaching and passing the Finsbury Park no.6 Up fast line colour light home signal located beyond the north end of Finsbury Park opposite GB sidings on the Up fast line as far back as after coming off the 'Harringay curve' that lead onto the long straight through Finsbury Park even in broad daylight as far as I can remember?.
An earlier photograph that I recall seeing that was taken on the Up fast line platform at Finsbury Park in GNR days shows a tall wooden signal post and featuring x2 co-acting home signal arms roughly where the aforementioned colour light signal was located in B.R. days.
The way it usually worked.
Trains travelling along the Up fast line between Harringay through Finsbury Park station to Holloway North Up (box) and later Holloway South Up (box) from the summer of 1970 onwards that were possibly going to be detained at the Finsbury Park no.4 semaphore 'starting signal' opposite the site of East Goods on the shallow right-hand curve south of Finsbury Park (when the starting signal was standing in the 'on' position at danger) due to the signalman in Finsbury Park no.4 'waiting an acceptance' from either Holloway North Up or later on Holloway South Up boxes. The train travelling along the Up fast line would first receive both the Finsbury Park no.6 Up fast line outer & inner semaphore distant signals (both signals underneath Harringay passenger box stop signals) would be both standing at 'caution' followed by the Finsbury Park no.6 home Up fast line colour light home signal that would be showing a 'yellow' aspect and the Finsbury Park no.4 colour light home signal standing off the far south end of Finsbury Park station would probably be showing a 'RED' aspect as the train approached it because all the signalmen that worked Finsbury Park no.4 would further 'check' the speed of an approaching Up train on the Up fast line before allowing it to 'run up to' the Finsbury Park no.4 'starting signal' standing at danger if the block section between Finsbury Park no.4 & Holloway North Up or later Holloway South Up was still occupied by a previous train or it hadn't been accepted 'on the block' by either the Holloway North Up signalman or later on the Holloway South Up signalman and this was done by keeping the Finsbury Park no.4 'colour light home signal' at danger (showing a RED aspect) and only 'clearing' that signal to a 'yellow' aspect after receiving 'on line' (train entering section) from Finsbury Park no.6 when the approaching train on the Up fast line was coming through the station platform so as to allow the train 'draw up to' the Finsbury Park no.4 'starting signal' standing at danger at a reduced speed to wait acceptance from either Holloway North Up or from the summer of 1970 onwards Holloway South Up after Holloway North Up was closed in 1970.
In the last couple of years before Finsbury Park no.4 was abolished around late 1974(?) the Up fast & Up slow lines semaphore 'starting signals' were abolished and replaced by three individual x3 aspect colour light signals on a bracket post opposite the site of the old East Goods sidings, the third colour light was on the new but temporary aligned 'Up Canonbury line' between Finsbury Park no.4 and Finsbury Park no.1 and featured a 2nd position left-hand route indicator above the colour light signal head to route trains down the embankment towards Finsbury Park no.1 with the straight route leading onto the Up goods line towards Holloway South Up and also 1st position left-hand route indicator to route trains from the Up goods line to the Up coal line heading towards the top of the 'Holloway bank' which was controlled by Holloway South Up. Also from memory after visiting Finsbury Park no.4 during 1972 I noticed that these three colour light signals (and the two sets of 'motorised facing points' in the Up Canonbury line leading to Finsbury Park no.1 and leading from the Up goods line to the Up coal line) were all being worked by 'switches' on the far left-hand end of the block shelf in Finsbury Park no.4 and not off the previous individual starting signal levers.
Amendment to the above post which I have added.
I finally got the above temporary track and signalling 'sorted out' that was worked by Finsbury Park no.4 after track and signalling alterations had taken place at the box during 1972/73 after checking my own 'hand drawn track layouts' between Finsbury Park & Holloway South Up circa March/April 1974 where the 'temporary' Up Canonbury line parted company via a set of 'motorised facing points' worked by Finsbury Park no.4 opposite the old East Goods sidings and headed down an embankment towards Finsbury Park no.1 and where the 'motorised points' continued on as the Up goods line (towards Holloway South Up) and immediately beyond these 1st set of 'motorised facing points' a 2nd set of 'motorised facing points' also worked by Finsbury Park no.4 lead from the Up goods line to the (old) Up coal line heading towards the top of the 'Holloway bank' (passing the x3 roads Hornsey Road sidings) and eventually onto Holloway South Up box.
