Baby Deltic no.D 5904 seen at the head of a set of quadarts passes Bounds Green box on the Up Enfield line approaching Wood Green station in 1959.
The train has got Wood Green Up Box No.2s Up Enfield line distant signal showing off (and also Wood Green Up Box No.4s Up Enfield line distant signal showing off as well although it is not showing in the picture) which later on by 1967 onwards would have been a bit of a rarity because I don't ever recall ever seeing ii pulled off?. Also the signal post it's self was changed at some later date after the picture was taken to a medium size straight metal tubular post.
http://steve-banks.org/images/historica ... 000_72.jpg
Bounds Green in 1959
