Anybody on here know anything about Workshop jacks?
To use for lifting wagons off their axles / Bogies.
What power supply required?
Availability of used items?
Workshop Jacks
Re: Workshop Jacks
Bryan believe it or not there are still some manufacturers active on the UK market. I don't want to leave names and numbers on the forum but I know a man who might be able to help you and will send a PM. What exactly are you looking for don't worry about being technical im in the trade so should be able to understand your requirements.
Re: Workshop Jacks
Something along the lines of a set of Matteson jacks.
We work on varying length vehicles from a Shark Ballast Plough at the shortest to a Sturgeon track carrier at the longest.
Or we may need to lift an 07 Tamper.
3 phase supply is not possible unless it is possible to use an inverter.
