Evening everyone
Could someone please help with advice on making/using a track gauge please.
I wish to build my own track to 31.5mm gauge and wish to turn up a set of gauges to achieve this. Since I'm new to this I thought I'd ask the experts what dimentions do I need to to turn to. I've seen a few different types of gauges both here and on other forums so I have a rough idea of what I'm making. I notice that the gauges have different spaced grooves on them, I'm assuming the two outer ones I would set the inner edges at 31.5mm however I'm not sure what to set the inner grooves at which I assume are for the check rails?
Any help/advice would be much appreciated
Kind regards
Pete
Track gauge help needed please
- greenglade
- Blink Bonny
Re: Track gauge help needed please
Ay up, Pete!
Try the Gauge O Guild. They're a fount of info regarding stuff 7mm...
- greenglade
Thanks
Somehow I posted this question on the wrong forum, I have a window open on my iphone for LNER forum, RMweb and G0G and guess I got the wrong one.
Sorry guys..
Pete
Sorry guys..
Pete
- Blink Bonny
At times like this I am glad that I'm a Technophobe.
The question has to be asked - if you want to build track to the finer standards why narrow the gauge even more than the incorrect 32mm, when Scale Seven puts the whole accurate package together?
- greenglade
It's a valid question and the answer is I'm new to this and while following threads on other forums have misunderstood the true scale of S7.
Now I need to decide which scale to build to, thanks for the replies guys.
Kind regards
Pete
Kind regards
Pete
Maybe, that weird broad gauge tramway, that they keep going on about!! It'll all end in tears, you know
