Carriage Codes
Carriage Codes
what was the code used to describe non corridor stock in a train formation, for example BCK is a Brake corridor composite, but what was the code for the equivalent Brake composite that wasn't corridored or gangwayed?
Many thanks for any help that can be given.
Simon Baldwin
Simon Baldwin
- sawdust
Suburban coaches
Well Simon a non gangwayed Brake composite would be a BC and a full third is a T. A Brake third a BT, I don't think you would get a 'C' because first class normally get a lavatory, hence CL
Sawdust.
Sawdust.
- sawdust
Have you ever noticed that mk3 and other 23 metre stock has C3 painted on the ends?Colombo wrote:On a similar vein, Mark 1 corridor carriages often have C1 painted on the ends next to the corridor. What is the significance of these letters and did any other carriage stock carry them?
Colombo
It is a gauging restriction because of the vehicle length. Pre mk1 stock was usually a tad shorter. The restriction was often about the next road or platform being empty. The bay at Whitby had such a restriction but on stock over 52'.
Sawdust.
I think the C stands for Coach as there are other gauge codes for different types of stock, but don't quote me. I have often wondered what C2 was. AFAIK all lines have a clearance rating, but I'm not sure how many passenger lines still have less than C3 as most modern multiple units are C3. Also I don't know how stock for lines with less than C1 clearance is classified (e.g. Hastings line pre-singling through the tunnels)
The appendices of this document defines the standards for the various gauges used.
Tim
Tim
