N Gauge Manning Wardle Dock shunter
wehf100
Post by wehf100 »
The GCR had a lot of old Manning Wardle locos on their books, most of which were used for shunting work at Grimsby and later Immingham docks. 407B was perhaps one of the longest surviving ones, bought in 1880's and withdrawn in 1929:0 see here: http://www.lner.info/locos/J/j61.shtml
So I thought I'd have a crack at modelling one- I chose 'Moltke' (named after a Prussian General no less!) which with its sister engine 'Bismark' was built around 1876, and was purchased from contractors in 1880, finally being withdrawn from Grimsby in 1920.
The model is mostly scratchbuilt in nicklesilver- the tank and smokebox casting coming from an old (1970's) Peco kit. As you can see below, a lot is to be done, namely footplate detail (toolboxes etc) and dreaded things like handrails, plumbing etc.
It sits on a Farish O4 class chassis, which with its short wheelbase of scale 11ft is pretty much spot on for the Moltke/Bismark locos (just too small for my preffered choice of 407B- d'oh!)
Any pointers/constructive criticism would be received warmly- this is a first attempt at N gauge modelling AND first attempt at scratchbuilding anything in Nicklesilver!
Will
p.s- please forgive the 'wonkyness' of the loco- nothing is soldered together yet- it is all built in sub assemblies.
W
richard
Post by richard »
Looks good, but I think it is well known that I have a soft spot for small Manning Wardles!
The castings look to be in good condition - N scale whitemetal seems to vary in quality a lot. Of course with Peco we expect them to be good!
Will this be one of the outside cylinder examples? What are your plans for the 04's "crank" (not sure of the proper name for it).
I should take some more pictures of my Y7 - the chassis and smoke box are coming together.
wehf100
Post by wehf100 »
inside cylinder engine, probably an M class, but to be honest this is a fairly generic model-
I will remove the jackshaft (crank) and shorten the coupling rod. It is just about right although the very short wheelbase is waay out really- what else is there in this scale with see-through spokes/ blackened wheels and tiny can motor that we can use instead?!?!?!?!
It will hopefully look a lot less odd when the buffer beams and sandboxes have been fitted. Also the cab will sit at least 1mm lower- my measurements were slightly out on this piece and it need some height removing- do'hh!!
wehf100
Post by wehf100 »
next job- (waaay ahead of myself here!)
turn this:
into this:
should be a nice simple conversion for something a little different.
Will
