Here are all the steam locomotive models I have had the opportunity to make so far.
Good morning everyone!
After opening up a few topics about the process of creating 3D replicas of locomotives designed by John George Robinson, I decided to change my style of presenting my work a bit. Instead, I have opted to share the renders in one place in summary form.
Be sure to share your thoughts below.
Here is my work done over the last few months, the number will grow from time to time.
- NBR J36 0-6-0
Re: Here are all the steam locomotive models I have had the opportunity to make so far.
Very nice work there, the level of detail is top notch.
1 of my favourite LNER locos besides the A1, A2, A3, A4 & P2 is the P1 2-8-2. Even though only 2 were built and both had long gone by the time I was born in 1973, since I saw a model of 2393 owned by Atlantic3279 on his youtune channel of thd same name and also running on Cliff Parsons The Gresley Beat layout in a youtube video, I have always wanted model of 1 or even both of the locos.
I have before now tried to build a P1 2-8-2 using the 8F loco chassis but this is completely incorrect, possibly an O1 or O2 class 2-8-0 chassis would make it as it should be but yes definitely the P1, maybe someday I'll get it right, who knows.
Wishing you well for 2024
It so happens that in 2022 I had the opportunity to make a replica of the P1 2-8-2 steam locomotive based on isinglass drawings. Taking advantage of a moment of free time, I decided to compare the P1 chassis with the O2 2-8-0 drawing, and all indications are that I have good news for you. Below in the attachments I provide photos of the locomotive in transparent view (maybe they will help somehow) and both chassis for both P1 and O2.
Also, my best wishes for 2024, I hope you will quickly build your model, which will please the eye of many a railroad enthusiast.
If you go back through Graeme King's thread, he built a very fine P1 using the ACE kits O2 frames.
- NBR J36 0-6-0
Many thanks for your replies, I look forward to posting pictures of the loco when I finally get to build it.
He also had some choice words to say about the standard of ACE's etches and their, er, fit and finish.....jwealleans wrote: ↑Sun Dec 31, 2023 7:10 pm If you go back through Graeme King's thread, he built a very fine P1 using the ACE kits O2 frames.
The B6 class received a different numbering and finally got textures.
I am pleased to present the finished steam locomotive "Sir Sam Fay". I decided to let my imagination run wild and make an extra stand for the model, was it a good move? I think it is a matter of taste. I encourage real experts to express their opinions.
Greetings
Greetings
Oto kolejny pojazd powiększający nie tylko moją kolekcję wykonanych modeli, ale również powiększający moją wiedzę w zakresie modelowania. Ten konkretny egzemplarz nr. 6112 jest tym, którego najłatwiej i najprzyjemniej miałem okazję wykonać. Podobnie jak w przypadku ówcześnie prezentowanej lokomotywy tu także zapraszam ekspertów to wyrażenia swojej opinii.
Greetings,
Krynio
Greetings,
Krynio
- nzpaul
Digital model making isn't a thing that's in my wheelhouse at all, but viewing the work of someone who's good at it is fascinating non the less. One thing, which might show up my ignorance of such things. Is it possible to lighten the background of the images? Viewed on a decent PC monitor they look okay but on a mobile device the loco can be difficult to see as the edges can disappear to a degree into the grey surroundings.
Thankfully, Google translate helped me out with the last post.
Class of heavy steam locomotives for mixed traffic classified as B7.
Hi Paul, thank you for giving me your own point of view and your own opinion. Your request has of course been taken into account, which is why the model below has a lightened background.
Greetings,
Krynio
Greetings,
Krynio
- H&BR Q10 0-8-0
That is really good, the lighting in particular is excellent.Krynio2 wrote: ↑Wed Jan 31, 2024 1:31 am Oto kolejny pojazd powiększający nie tylko moją kolekcję wykonanych modeli, ale również powiększający moją wiedzę w zakresie modelowania. Ten konkretny egzemplarz nr. 6112 jest tym, którego najłatwiej i najprzyjemniej miałem okazję wykonać. Podobnie jak w przypadku ówcześnie prezentowanej lokomotywy tu także zapraszam ekspertów to wyrażenia swojej opinii.
Greetings,
Krynio
Jim de Griz
After a slightly longer break from posting, I have the opportunity to introduce my NER class S3 / LNER B16 4-6-0,
which I have enjoyed creating.
Freshly textured, with high quality details and a superb GCR paint job already completed! In front of you is the 'Butler-Henderson' - Robinson's passenger project!
In the first photograph, note the buffers, and their textures
In the second photograph, note the multitude of stripes in this livery and the nameplate with which No.506 rode
I present a project that I have been working on for over two months.
The result is two 4-6-0 steam locomotives - a Class 9P four-cylinder express locomotive and a Class 8N mixed traffic locomotive.
I'll start with the 8N...
In 1918 they were introduced along with the similar Class O5, thus creating the first 8N no.416 with a cutaway cab, but a later batch had cabs with side windows. They looked attractive and had clean lines, were apparently free running and were excellent steam locomotives. They lasted until 1947 when, along with most GCR 4-6-0s, they were replaced by Thompson B1 4-6-0s.
Here is the main view of the model:
Here is another view of the model:
Class 9P...
Although not regarded as an outstanding success due to a tendency for high coal consumption probably due to the relatively small grate, 26 sq ft and more particularly short travel valves, they were in the right hands able to put in some good performances and as other Robinson designs were reliable, simple, robust and handsome. Some of the class were rebuilt with Caprotti valve gear in an attempt to overcome the weakness, but not 1165, which however, due to coal shortage was for 2 months in 1922 converted to burn oil.
Greetings, Krynio
Class 9P...
Greetings, Krynio
