Micks 4mm LNER Models
- Dave
Re: Micks 4mm LNER Models
Ha... now that explains a question I had regarding the different rear steps I had noticed when looking round the A4's at the NRM.
Couple of pics to show the difference for the unenlightened...like me.
- richard
Does DoC have a corridor tender? I can't remember off hand, but that looks like it might be a corridor connection in the background. Perhaps that is the primary difference...
- Saint Johnstoun
It's an easy one to make, indeed I suspect that Hornby may have even released some models with the wrong underframe on! A couple of mine were running around with the wrong steps until I sorted them.
D of C does have a corridor tender. The steps are further back on the corridor tenders as the tender body is slightly longer - you can see the gap on the non corridor tender behind DDI!
- Dave
You had me worried for a bit that I had miss filed my pics, yes it does have a corridor tender and just for you Richard.
Bachmann V2 upgraded as far as I could go without chopping the body to bits. This is horrible body as said so many times before.
Body rubbed down to remove hideous top seam . Re painted New numbers and Lettering as Bachmann use a wierd pale yellow/gold colour and Loco relined and additional lining added to Cab windows using HMRS decals. Front coupling nem pocket filled in.
Wills Chimney
Brassmasters etched Reversing and Ash pan levers. Floor supports and front steps.
Hornby A3 provided Dome, Smokebox Door,Oil box, Superheater Covers , Vacumn return pipe, snifting valve, front buffers, screw coupling and vacumn pipes.
Hornby A4 safety valves
Re glazed , new sandbox fillers, etched cabside sight screens,new front footplate handles and lamp Irons repositioned front frames thinned. Real coal ,etched fire irons and lostwax brake standards to tender.
Looks a bit better
Wills Chimney
Looks a bit better
On a Horsebox/CCT train
Hi Mick,
The improved V2 does look an awful lot better now! Impressive work as always.
I received a Branchlines price list this week and I see they list a replacement chassis and detailing pack for the Bachmann V2. Has anyone used it and is it any good?
Not on my one !!!
I presume it is for the old style body with fittings for the old type chassis ?
Jonathan: TW used it under a NuCast lump and expressed satisfaction with the result. I do have various bits of etched V2 chasis from different sources lying around, possibly enough to make a whole one including driving wheels, although I'm not sure whether to keep the parts for my own use. Not sure if they would suit your plans either.
A change from refurbing knackered rtr , some kit building has been done,.
51L ex NER
51L ex NER
ABS
D&S Hull and Barnsley Dia 18 Van only the second H&BR wagon/van I have ever managed to fine via ebay . Very nice etched Brass kit.
- Tom F
They look lovely Mick.
May have to pick your brain over what engineering stock you have.
Tom Foster
No problem
