Steve a man of your talents will be able to produce underframe details from plastic rod, etc after seeing the great job you have done on that Guards Ducket.Atso wrote:Hey Rob! Thanks for the comments.
You're right, but carefully cutting the sides off the Dapol coaches they can be reused. Building non-corridor stock requires the compartment sides of two coaches, so as you thought, every two conversions will hopefully produce three coaches. Just need to find some under-frame details and decent bogies for the non-corridor stock!
I'm also going to try and be clever and turn my first two non-corridor coaches into an articulated unit (most likely a first/third pairing).
Scratchbuilding an N gauge Gresley coach
- Robpulham
Re: Scratchbuilding an N gauge Gresley coach
Rob,
Thanks for the encouragement - I think you've got more faith in my abilities that I do!
The guards ducket is a piece of 40 thou plastic card filed to an approximate shape, it is far from perfect although the pictures seem to do this bodge more justice than it deserves...
- Robpulham
You know what they say mate the camera never lies!!
