Some serious modelling was needed to maintain (relative) sanity. I do quite like making signal boxes, even though I have so far only made one actual signal. My railway is built in and represents County Durham. It's (fictional) location is on the boundary between the Northern and Central Divisions of the NER. For the south end of my junction station I wanted a CD type signal box. So, with due examination of splendid reference materials (listed below) I am making a NERA type C2c Cabin, based on Darlington Springfield. Similiar Cabins were at Castleton on the Eskdale Line, and (one third as long again) at Battersby, also on the Eskdale Line.
Here is what I am trying to achieve:-
To fit my location the access porch has been moved to the opposite end, which in fact makes it like Castleton. The locking room door also needs to be at the opposite end. I am worried that I've placed it far too close to the front where it would conflict with the locking frame itself. I may yet try to change that.
Since it is quite a complex structure I thought of it as a kit, with the separate parts needing to be thought out and assembled 'flat', and then assembled into the built structure. This has to allow for the paneled brickwork and (as will be seen later) the elaborate hipped roof.
Materials used are:-
2mm acrylic sheet (I have a large sheet of this bought years ago. I think it was supplied for green houses.)
1.5mm acrylic sheet
The windows are modified from a laser-cut set of NER windows produced by
..Stoneybridge Structures.. - except for the locking room windows, which, as in the picture above had to be built up individually.
A variety of plastic sections and sheet from Evergreen have been used for the frames and the structure.
The advantage of these materials is that they will adhere using Plastic Weld.
The brickwork uses brickpaper glued to thin card with Rocket Card Glue, and then the brick layer is glued to the acrylic with a contact adhesive.
The card is mainly from cereal packets.(in my case Wheetabix (tm) and Shredded Wheat (tm)). This has the advantage of allowing for prototyping; 'bodged bits' to be discarded with no material cost!
Sharp scalpel blades are essential!
