On my workbench - Raven A2 Pacific
Frazmataz
Post by Frazmataz »
Fantastic job on the painting! I would also like to know how the wheels were lined :)
richard
Post by richard »
It is looking a grand model.
My opinion of the Raven A2's aesthetics has definitely increased since I recently purchased the relevant volume of Yeadon's Register.
45609
Post by 45609 »
The lining of the wheels and some of the loco body lining has been done with spring bow compasses or bow pen and gloss humbrol enamels. A photo of the tools is attached.
To explain in a little more detail before painting the wheels have a centre dimple put on the axle ends to give the point of the compasses something to register into. When it comes to the lining the black circle is done first and then a minimum of 24 hours later the white line is done. The paint is used neat from the tin as it flows nicely but does not bleed.
On the loco, taking the red running plate line as an example , the straight lines have been done with the bow pen. Then the compasses are used to to do the curved portions. The point of the compasses is replaced with a piece of parallel brass wire that protrudes beyond the tip of the pen. Loaded with paint the pen tip is set very close to, but not touching, the brass wire. I then run the bottom edge of the brass wire along the bottom of the running plate whilst keeping the tip of the pen in contact with the model. All being well a nice smooth curved line results that follows the contour of the running plate.
I has taken me quite a long time to get proficient with hand lining techniques but the results, I feel, are worth it. It really makes you appreciate how incredibly skilled people like Ian Rathbone and Alan Brackenborough are. I've chickened out in a number of places on this model and resorted to transfers.
Cheers....Morgan
(58.96 KiB) Downloaded 177 times
rob
Post by rob »
Outstanding work Morgan,and I have learned a lot,some very useful tips re building and painting here!Not only that but I thought I knew these locos-never spotted the front frames were lined green!
With regards to the firebox lining,Vintage LNER Magazine no's 22 and 23 had a comprehensive article on the class .On P3 of 22 there is a reasonably clear photo of 2400 at Gateshead,described as a later view with Westinghouse removed and cabside no.In this photo there does not appear to be lining on the firebox.My Yeadons is not accessible at the moment but I presume you have scoured this already!Sorry but I have no way of scanning this as Jonathan was kindly able to do for me with a J12 photo some time back,but I hope it is some help.
45609
Post by 45609 »
Thanks Rob. I quite enjoy passing on my modelling experiences and techniques. It is pleasing to know that others might be getting something useful out of it.
I actually don't have a copy of the appropriate Yeadon's volume and the LNER magazine you mention sounds interesting. Is there anybody else out there that might be able to help out with a copy of the article? I'll be quite happy to cover the cost of any copying/postage etc...
The references that I have used are Vol. 2A of the green books, Locomotives Illustrated No. 93 and part 1 of the Michael Bonavia History of the LNER.
Cheers....Morgan
rob
Post by rob »
Morgan,could you hang in there until Saturday? I should be able to access my Yeadons by then,and I think I have locos illustrated somewhere,so I can do a more thorough search for you.
Hi
I have Yeadon volume. Which Loco are you modelling? There are only a few photos of the A2.
2402 3/4 view appears to have firebox lined. Westinghouse fitted, Tender with number underneath LNER ,frames lined in front of Smokebox
2403 better view definatley lined as above.
2400 3/4 view again poor but appears to have firebox lined etc Westinghouse fitted numbers on tender
Hope this helps
Mick
rob
Post by rob »
Hello Morgan,
I have acessed Yeadon's,the relevant Locos Illustrated and RCTS Vol as well as Vintage LNER magazine.Interesting,but I'm afraid not conclusive.Certainly the shots in photographic grey show no lining on the forebox of any of them,2400 in NER greyc1922,2402 in LNER grey c1924(one of the photos shows 2404 but is apparently a Stalinesque re-touching of the original plate for 2402!) .I read the other photos in Yeadons exactly as Mick does and by the way get the impression Willie Yeadon had little time for the class,poorly represented for such interesting locos.In particular the shot of 2403 on top of p5 of Yeadon clearly shows the firebox lined and I think this is significant.All the in service photos in Locos Illustrated though larger and clearer than any others are at such an angle that its not possible to judge.The RCTS vol is equally unhelpful,so I am left with Vintage LNER.
I am happy that the photo of 2400 mentioned earlier looks unlined on the firebox- but then on close inspection you cannot see the lining on the last boiler band either,so it could be the angle.Its possibly absent from 2403 on p14 but equally a small but lovely shot of 2402 at York loco beside 2579 appears to show lining!
Hazarding a guess,but very much a guess,I think it may have been omitted from the works photos in the interest of symmetry,as the firebox is so short,but was probably present in service.
I am more positive the frames were always green,even late in the day and with Gresley boilers which certainly had their firebox lining.If its any help there are some very clear photos of the Atlantics in Locos Ill. and all show firebox lining so I would assume there was no technical problem with the paint that would have precluded using it on the Pacific fireboxes.
So I'm afraid at the end of the day I'm probably as much use as any comission of enquiry,and I cannot come up with a conclusive answer!
On a more positive note,the lining could easily be added (or painted out!)at a later date if more definite information presents itself.Look forward to the completed job,whatever you go with it will be spectacular!
45609
Post by 45609 »
Mick, Rob,
Thanks for looking through Yeadon's etc... for me. It's a shame that we can't find an answer to the question. I did notice that all the Atlantics appeared to have lined fireboxes (even in works grey) and this is why I have been deliberating over this. I also found this photo on John Brighton's website. But the second photo shows 2402 ex works from Darlington. You can see the boiler is lined. Also the cab edge and firebox base but why can't you see anything on the firebox itself. I think I'll line round the base of the firebox see how it looks and then decide.
cheers....Morgan
(48.06 KiB) Downloaded 154 times
(54.71 KiB) Downloaded 142 times
Hi
A drawer search has found below picture it is very small and grainy. I have magnified it and I cannot see any evidence of firebox lining. The front frame and straight section below firebox are lined. Hope this helps.
Mick :)
rob
Post by rob »
I enjoyed the research and must confess to a vested interest anyway!Your plan of action is certainly the best approach,especially in the light of Micks photo not showing lining.Did you notice the kink in the footplate of the kit built loco?Very similar to my example,must have been a problem area for some builders,leaves the loco very distorted looking,I hope I will be able to rectify mine when rebuilding.Keep us posted!
Hi
Just sen this months BRM magazine. There is a small article on LNER livery therein is a excellent picture of 2402 side on . Firebox is NOT lined, Green is carried up onto roof to underneath rainstrips
Mick :D
45609
Post by 45609 »
Hi Mick,
Thanks for letting me know. It's just typical that now I've finished the model another picture turns up. I'm glad I didn't line the firebox. A few pictures of the finished loco are attached.
Cheers.....Morgan
(239.14 KiB) Downloaded 168 times
(232.32 KiB) Downloaded 125 times
(234.9 KiB) Downloaded 131 times
(231.5 KiB) Downloaded 132 times
(228.73 KiB) Downloaded 137 times
Hi
Fantastic job , re my last comment it is a picture of 2402 in the early LNER livery (number on tender) therefore the cab roof maybe as you have it?? either way one to be proud off.
How does she run ?? I cant imagine her liking any sort of curve?
regards Mick :D
Frazmataz
Post by Frazmataz »
amazing job on that locomotive! If it wasn't for the non-blackened motion, that could easily be mistaken for an RTR model of the latest standards :D
