- greenglade
Hi guys
One or two of you will already be aware of this but thought that I would give a heads up to all on this festive day.
Back in the summer, I was in discussion with Martin Evans regarding publishing 4472's build in the Model Engineer magazine. I can now announce that barring any unforeseen issues the series begins from the 1st Jan 2021, papers have been agreed and signed.
Diane will be sub-editing and there may be a special day/event coming up in 2023, we shall have to wait and see if this comes to fruition, it would be a very proud day for me if it did. Needless to say, this series will run for some time, years as Martin has told me, my job now is to keep going and get her finished close to 2023. There will still be work to do after then I'm sure but I'll get her as presentable as possible and at least looking finished, there should only be small details left to do by then, fingers crossed.
I hope you guys don't get too bored seeing a repeat of what has been posted here over the years although most updates now have been rewritten for the blog. This forum has been with me for some time now and I thank all of you for your help, guidance and support during those years.
Merry Xmas
Pete
Merry Xmas
Pete
- greenglade
I wonder who this Flying Scotsman model build series which begins in the ME today belongs too...
Pete
Pete
So it was the fame that you were seeking, rather than the completed and working locomotive
- greenglade
Haha...I already have fame with mutiple film credits...Atlantic 3279 wrote: ↑Sat Jan 02, 2021 4:08 pm So it was the fame that you were seeking, rather than the completed and working locomotive
This time I'll just be happy to complete the model and if my series helps/encourages others to do the same, then thats great. I also need to get the loco finished so that I can get on with building those Gresley teaks to go with it. Just need to get drawings sorted.
Pete
I hope to be able to see her running, will she be pulling the train to Edinburgh?
- greenglade
Ahh...well I certainly have a wish to have her pulling the 1938 Flying Scotsman train rake. .alas, I may get 1 or 2 of the carriages built if I can find the drawings but I can't see me living long enough for the entire rake.
It's a dream though...
Pete
- greenglade
Tonight's update (sorry for the delay, I had a break over Xmas) covers part 1 of the crosshead fabrication. In Don's words, he states that the trickiest part on the whole model was probably the steam sander bodies? well tricky maybe but the crossheads are going to take some time to complete and probably as much work as the coupling rods with their fish bellied profile which included the fluting. Anyway, here's part one which covers getting the blanks ready for profiling.
http://4472flyingscotsman.co.uk/crossheads-part-1/
Pete
Pete
- greenglade
Part 2 of the crossheads, these parts may take a few more entries before completed, I'll probably throw in the drop links too. In this entry, we have the slipper oilways, gudgeon-pin holes and piston rod hole. A few more changes from Don's drawings.
http://4472flyingscotsman.co.uk/crossheads-part-2/
Pete
Pete
- greenglade
Part 3 of the crosshead construction.. we have a long way to go before these are finished but we do have some progress...
http://4472flyingscotsman.co.uk/crossheads-part-3/
Pete
Pete
- greenglade
Crossheads Part 4... I'm now at a stage where I can breathe a little easier, I have finished the machining for the front area (rear will be the last part to do). From this stage on it's all down to hand grinding/filing and polishing, I have made a very small start at the end of this entry. On a footnote, can anyone tell me what a full-size cotter pin measures? preferably that as fitted to an LNER/BR Pacific? thanks
http://4472flyingscotsman.co.uk/crossheads-part-4/
Pete
Pete
- greenglade
Crossheads Part 5... there's a lot of work in this one and I still have a long way to go. I was hoping to have finished the crosshead and mounting plates for this entry but the lathe decided to shred its V belt which meant I couldn't turn up the last 'button' required. probably a good thing really as this entry was getting a bit long. Hope you find it of interest.
http://4472flyingscotsman.co.uk/crossheads-part-5/
Pete
Pete
- greenglade
After 4 weeks slog the crosshead bodies are more or less complete, I have forgotten to curve the top edge of the sides which I'll take a look at tomorrow.
http://4472flyingscotsman.co.uk/crossheads-part-6/
Pete
Pete
- greenglade
The crossheads are very close to being called finished (for now that is, there will be some fine polishing for all parts made to date at the end) As can be seen the oil reservoir has been made and bolted to the slipper. I decided to silver solder the inner bolt heads as the model doesn't need 4 practical bolts to hold the reservoir on, makes life easier. The top side face of the crosshead where it touches the slidebar has also been rounded off as mentioned last time. I have made a 5/32 x 40 oil plug with a small central hole to avoid a vacuum which would stop the oil flowing.
The last job to do here other than the 'drop link', is a small copper pipe which comes out of the bottom of the reservoir, is angled approx 45 degrees towards the front (others will be handed) and then snakes back to the centre of the gudgeon pin. I hope to post a blog update covering all of this end of the week, count this as a taster...
Pete
Pete
- greenglade
good day, all.. well, I think that I can finally say that the crossheads are completed. I still have the drop links to make but they are separate parts, I'll make those next. I do have one final operation to do which I detailed in the blog, it's only cross-drilling the little end journals, that will be my first job Monday.
I also listed the next stage of the build, when that work is done, (could take a while) I'll have pistons connected with the wheels, another important milestone reached.
http://4472flyingscotsman.co.uk/crosshe ... ng-system/
Pete
Pete
I am again seriously impressed, and now more than ever painfully aware of the amount of detail missing from "very good" small scale models...
