First P2 Pic from Hornby
- Saint Johnstoun
Re: First P2 Pic from Hornby
Studied the test shot at Perth MRE yesterday and they have got the boiler cladding right (eliptical or egg shaped above the boiler centre line!)
I'm now even encouraged to believe that the upper sides of the boiler may have the correct shape as seen from above, viz:
- Saint Johnstoun
Moving on to 2003 etc. a close study of these shows that the boiler cladding is not parallel along the top of the boiler so it would not be possible to do an easy modification of 2001 to a bugatti front.
Now for that I may have a cunning plan, not involving a turnip.
- 60800
If you change your mind Graeme, I know a cunning fox who can get you a turnip shaped like a thingy.
Back (and forth) to sanity, did anyone get a good look at the bearings, contacts and drawbar?
Are not Hornby considering producing a model with the streamlined front end anyway?Saint Johnstoun wrote:Moving on to 2003 etc. a close study of these shows that the boiler cladding is not parallel along the top of the boiler so it would not be possible to do an easy modification of 2001 to a bugatti front.
(Although hopefully they won't do so until I've got some more money!)
Sorry, don't know how the duplicate got posted
I shall not bother to post duplicate replies but 'informed sources' have previously indicated that all members of the class will eventually be produced...
- 60800
Right, just need to wait to put my order in for 2002 with streamlined nose then
- Saint Johnstoun
On trying to draw SK on the subject on Saturday last at the Perth MRE the answer was if the first model sold well then other members of the class would be produced. The chassis has been designed to allow for this.
Hattons reckon the P2 is due on or after Monday 23rd December 2013.
Wow, only just seen this. Impressive. I was resolutely not going to buy one since I can in no way justify it. Now I'm not so sure.
AJ in Bradford
My Ivatt N1 3d printed models available here http://www.shapeways.com/shops/AJModels
My Great Hotton Blog (Bradford-Queensbury Lines 50s) https://ajmodels.wordpress.com/
- LNER Thompson L1 2-6-4T
If SK did mention the chassis that way, you should have chipped in asking if it also converts to a 4-6-2...Saint Johnstoun wrote:On trying to draw SK on the subject on Saturday last at the Perth MRE the answer was if the first model sold well then other members of the class would be produced. The chassis has been designed to allow for this.
- GNR J52 0-6-0T
The sample looks pretty good. Will have to find room for this on the loco roster.
Matthew Davis
Matthew Davis
Now in green:
http://ow.ly/i/2HwNu/original
Will
viewtopic.php?f=3&t=9293
My Blog
My Blog
