Going back to something I said a couple of pages ago, i.e.
Atlantic 3279 wrote: while I was measuring up I noticed that other dimensions of the valve gear, such as the length of the eccentric rods as per the Isinglass drawing, don't match comet's version of the V2 valve gear that I am hoping to use. The Comet eccentric rods appear to be too short, so rather than "simply" fitting mainly standard Comet V2 valve gear it looks like I'll have to brew up another combination of Comet's parts and longer items (shortened) from the RTR model.
I've done some more measuring tonight, including some dimensions obtained from broadside official photos of actual locos, and if we keep everything in 4mm scale, this is what I reckon about eccentric rod lengths:
Comet "V2" etch = 18+ mm, say 18.2 by my best estimate.
Green Arrow V2, official photo = about 21mm (possibly 20.
Great Northern A1/1, official photo = about 21mm (possibly 21.4)
Great Northern, Isinglass drawing (not the same both sides!) = about 21mm
A2/1 official photo (development of V2 but with definitely shorter, more steeply inclined eccentric rod) = about 18mm (possibly 17.
So if I've done my measuring correctly, this could support the suggestion that Blink Bonny made to the effect thet Great Northern's valve gear used V2 parts, but Comet's interpretation of the V2 valve gear is well off target. I can see that by erring on the short side with the eccentric rod they may have sought to ensure that it would not foul the rear end of the slidebars on its forward stroke, no matter how inaccurately assembled, but it doesn't help those who have built accurately and who wish to see their expansion links oscillating through the correct angles. It won't do on my A1/1 either - 20mm would be acceptable according to my assessment, but not a mere 18mm.
Oddly enough, it looks as if the 18mm length would be near enough the correct scale one for an A2/1, A2/2 or A2/3. I believe that Tim E has managed to use the Comet eccentric rods on an A2/3 conversion that he has assembled, although I couldn't see how I could safely accommodate much more than 16mm on my modified Bachmann chassis. Were my slidebar ends too far to the rear I wonder, or does Bachmann's return crank create too much travel of the rod??
Those "Smilies" above are not intended - 'tis the unwanted consequence of typing a figure 8 followed by a bracket
