Micks 4mm LNER Models
Re: LNER Models
Completed signals now on my layout Helensdale :shock: :shock: .
Two more Bracket Signals (nearly done!!) and Ground Signals (on order) for the crossovers still to come.
MICK
Robpulham
Re: LNER Models
Post by Robpulham »
Looking good Mick,
I am sadly a long way from needing signals - two ovals of track not even pinned down yet. I enjoy building stock too much.
Re: LNER Models
A start made on the the next part of the Silver Jubilee Set , 1st Brake / Semi Open Artic pair
Re: LNER Models
Interiors done , bogies also built ,next roofs and painting
Semi open 1st
1.jpg[/attachment Brake 1st] [attachment=0]2.jpg
Tom F
Re: LNER Models
Post by Tom F »
looking brill chap
Very helpful for when I start my Articulated Set!
Tom
Tom Foster
M Gair
NER J27 0-6-0
Re: LNER Models
Post by M Gair »
Hi Mick,
Looks good. From all the comments I have read regarding etch brass coaches being pulled by Hornby A4's, you will need to add extra weight to the loco for pulling power. That is if you are using Hornby A4's.
any way keep up the good work and I look forward to seeing more.
Mark
beeman
Re: LNER Models operable 4mm semaphores
Post by beeman »
Have you made these operable ? or are they fixed, I have been assembling some 4 mm Ratio signals. They were fiddly some 20 ish years ago and still are today. The main complaint i would make is that the bellcranks and laddering are not sufficiently strong.,some I made years ago have gone brittle. The new additions are little better. I accept that the parts are tiny but considering the advances in plastics materials technology that must have been made over 25 years I would have thought Ratio would have improved their choice of materials.perhaps the problem is getting better material to flow in the moulding process. It would be interesting to hear their comments. For all that the mouldings are excellent in detail. of course the original Ratio was taken over by Peco. same moulds being used. My challenge was to make them electrically operable .I decided to try Flexinol wire, making them so they could be 'plugged' into the baseboard from above , the main reason being facility to remove in the event of trouble. They all work on the bench and now fitting to the baseboard. Must admit they look great. The most involved so far has been to operate 3 arms on one array. One drawback I feel I am now to encounter is the slight variation in current they need, may require to fit simple adjustable current controllers to each operating arm. proceeding with success so far.
Re: LNER Models
Hi
The arms work but I have not attempted any further.
I have found them very hard work to make. The kits are all MSE manafacture. There are problems with various parts either being too weak or simply the wrong size as etched. As a result I have had multiple breaks of various parts due to them after filing to fit, being too thin. I await Ground signals at the moment and will be contacting MSE regarding the problems I have had.
Good luck with yours please start a thread with some pictures or add to the signalling thread already on the forum
Mick
Re: LNER Models
Last two brackets done !!!! Still await Ground Signals. MSE were very helpful and made some good suggestions on how to build these things. I wont be rushing to do anymore , I would rather build rolling stock anytime !!
A bit closer
Re: LNER Models
Jubilee 1st class twin bodies and roofs ready for paint
interiors simple push fit in due course
James Brodie
Re: LNER Models
Post by James Brodie »
Ex NER Mineral wagons-we knew them 21T hoppers as 'T' wagons then later Double Xs-XX or an X for the 13T version in either case wood or steel.
I possitively drooled over the workmanship of the hoppers shewn, makes my poor examples(as yet not completed) a sorry attempt at model making yet they inspire me to as my school reports used to say "could do better".
The partial view of the engine in No4 is a scratch ex NER 4-8-0T class T1. These were the first engines I ever fired on the Newport hump yards.
jim brodie
Re: LNER Models
Renamed Hornby A1 Great Northern models
Sir Frederick Banbury
Solario
Re: LNER Models
Another NRM A3 renamed Singapore
Re: LNER Models
One side of the Silver Jubilee 1st pair finished
Mick
rob
Re: LNER Models
Post by rob »
Great to see the layout Mick,looks superb!...wonderful job on those signals too,I've only built a single post slotted,don't like to even contemplate what work went into yours! They add so much to the layout though you must consider it time well spent by now!
Rob
