Both the stovepipe and the rimmed chimneys look very odd on the Bachmann A1s. It has been gnawing at me for years! Am about halfway through my fleet with the conversions, the relief when the paint dries and it looks so much better is soothing!Atlantic 3279 wrote:Now I see why you want to be rid of that joint
I've not paid much attention to the Bachmann "plain" double chimney before.
Simon - only now you mention it have I noticed on the later lipped chimney - It's better than the early one - but still not quite right...
See what you think now - chimney on the left is Graeme's cast one (not stuck down properly here) and on the right the original.davidwest wrote:Simon - only now you mention it have I noticed on the later lipped chimney - It's better than the early one - but still not quite right...
I personally can't stand the gap. Particularly if - as on a few of mine - it is not quite fitted correctly into the moulded lower half. Have done five out of nine A1s so far, working on number six as we speak...!
Yippee! I've actually managed to start my second A2/3, the "timed conversion". Not a lot to show so far, as besides the cleaned up resin castings all I have done is prepare the parts on the Comet valve gear etch, assemble those that make up the motion bracket, and suspend the expansion links / radius rods / reversing levers from that - but it's start. A small but important psychological victory.
You can tell that my fuss with the painting of exterior woodwork on the house is now more or less finished, can't you?
Piccies! Piccies! Piccies! Piccies! Piccies! Piccies! Piccies!
Gimme chance BB!
Actually, I didn't want to repeat old coverage, but as I've made the bracket up first, with superb accesss as it was all done entirely off the chassis thanks to now knowing the previously successful arrangements and dimensions, a picture or two of the result may be justified. I've yet to add the insulating plastic under-layer to the stretcher, and split that into R and L halves. Also I still have to turn-in and solder the bottom ends of the outer brackets, which I may not do until I have some slidebars to support as these have to join the bracket in much the same position. But it's all together, straight, square, and the expansion links rock back and forth without fouling any parts of the bracket and without slopping from side to side, so I shouldn't have any trouble keeping the eccentric rods running true, rather than drifting inwards and fouling the con-rods or return cranks (as initially happened with my first A2/3 build).
Not the best pictures I've ever taken........
16/2/12 As I am now obliged to either "pay up" for a "premium account", or selectively reduce my pictures hosted on imageshack, or just let them wipe off all of the older ones at the end of this month, I have now deleted all of the pictures ahowing the assembly of the second A2/3 from my resin parts. I can however supply all of the necessary pictures with captions/text as an e-mail attachment should anybody want to see them again.
That looks rather exquisite Graeme!
Origami in nickel silver...
No further piccies yet, but the loco (originally Bachelors Button) is now as fully dismantled as it needs to be, save for removal of the smokebox door, i.e cab and boiler separated, off running plate, which is off the chassis; cylinders and motion off; front bogie and carrier chopped from keeper plate; sandboxes and other projections cleared off the front of the chassis; slot for motion bracket stretcher deepend; running plate cut in two; raised bosses at rear end narrowed ready to take narrower cab and exposed rear corners of firebox.
It's amazing to see how quickly the work can progress when problem-solving on the prototype loco has already been done, and thus you know where you are going at every stage. Several jobs that have no immediate relationship can all be dealt with whilst the correct tools are at hand, and the workbench remains remarakably free of accumulated tools, parts and general mess!
Mrs BB says: Take note of this, BB and learn.
My workbench looks, as usual, like London's East End after the Luftwaffe visited in 1940...
By (apparently) popular demand, some progress pictures, but owing to pressure of time, notes/captions (if needed?) will have to wait:
And finally, with old valve gear dismantled, new stretchers for motion bracket and cylinders built and fitted, plus a dry-run to check fit with some of the major resin parts:
I'm even remembering to keep a careful tally of time spent on this one......Most subjects, models and techniques covered in this thread are now listed in various categories on page1
Coming together nicely.
I am pleased to say that I now have a Apple Green Tudor Ministrel on its way for a bash at a A2/2 using your resin parts .
Comet V2 Valve Gear on order and a Hornby Streamlined Non Corridor Tender ready for conversion too.
Should keep me busy for a while Get ready for a few questions
Looking excellent there Graeme - I take it it'll have the rimmed chimney with banjo dome?
Glad to hear that you are almost ready to make a start Mick. You'll be asking questions at just the right time, as I may actually know the answers based on the work I'm doing at present.
Correct re: dome and chimney Simon. I plan to keep this one as straightforward as possible, keeping life easy for me and (I hope) illustrating for others the minimum of work necessary to effect a good conversion.
Looking good, Atlantic. Very good.
