NER SNOWPLOUGHS
Bryan
NER SNOWPLOUGHS
Post by Bryan »
In the latest NER Express from the NERA a small article mentions a firm called Prolix models of Keighley are producing an O gauge model of NER Snowplough no 12.
Does anybody know anything about this firm as I have never heard of them before. (maybe that isn't hard though)
A web address was given in the article but it comes up dead.
Bryan
Post by Bryan »
Finally got the address to work.
The plough looks OK any comments anyone.
http://www.prolixmodels.co.uk/
lnerjp
LNER J94 0-6-0ST Austerity
Post by lnerjp »
Hi Bryan, Had a quick look at one of these a month ago at a show, and on first impressions I thought the mouldings very good and would very quickly (in minutes) build into a complete model. Could be improved if you are prepared to put a little extra work in to make a interior and would benifit from a brass/nickel silver chasis. I also thought £60 was a lot of money for not a lot, but going by other vacuum cast resin kits, its about the going rate, guess its not cheap to produce. I would have bought one there and then if I'd had the cash and will most probably buy one in the future. Hope this helps J.P.
J.P. Venus
richard
Post by richard »
It does seem a lot, and I thought resin was meant to be one of the cheapest kit mediums - especially for small volume products. The quality of resin castings also appear to have improved a lot over the years.
Tempting, but I'm not sure if a Y7 or MW 0-4-0 could handle any serious ploughing with one of those!
Richard
Bryan
Post by Bryan »
Would the provision of a nickel silver or similar chassis take away from the prototypical timber chassis?
lnerjp
Post by lnerjp »
It all depends on your own personal modelling standards, as the kit comes there is no provision for compesation or springing and the bearings are pressed in on the internal sides of the plough. The entire interiour of the plough is hollow there isn't even a floor, my feelings are that if I was building this kit I would probably build a internal compensated chasis and floor. As I have said this would be internal to the model and therfore would not take away from the timber chasis as it could not be seen without picking the model up and turning it over.
Cheers J.P.
J.P. Venus
lnerjp
Post by lnerjp »
If you decide to get one Bryan, I would be interested in how you get on, keep us posted.
Cheers J.P.
J.P. Venus
