Hi all,
Having almost completed my cardboard Atlantic, I've totalled up the cost of the model and having purchased fittings found that this has cost me more than using a 3D printer. As the original reason for building the model out of cardboard was to keep costs down, I've decided to return to my CAD work and designed this to fit onto a Farish V2 chassis (with rear pony truck removed!).
Back to the 3D modelling
Re: Back to the 3D modelling
I'll see your loco body and raise you a set of wheels..............Atso wrote:Hi all,
Website: http://www.mousa.biz
Hi Bill,Bill Bedford wrote:I'll see your loco body and raise you a set of wheels..............
I've got a set of N gauge 4' 8" drivers to be printed some day - but have you considered that the body should hopefully be printed in stainless steel - so I guess I've raised you again!?
How did the GCR tenders turn out in the end?
I've looked at the stainless printing and I'm not at all sure whether it will be worth pursuing. The combination of price, surface finish and a minimum wall thickness of 2mm mean that the process will be difficult to use economically. I am, however looking at using a different route though it still needs a lot of work.Atso wrote:Bill Bedford wrote:I'll see your loco body and raise you a set of wheels..............[/quote
Cast frames?
Now this looks different
Hi Bill,Bill Bedford wrote:I've looked at the stainless printing and I'm not at all sure whether it will be worth pursuing. The combination of price, surface finish and a minimum wall thickness of 2mm mean that the process will be difficult to use economically. I am, however looking at using a different route though it still needs a lot of work.
Interesting to see you're metal printed chassis, have you thought about sand blasting them as this is what I am considering for my body. Also if you look one Shapeways's forum there is an interesting discussion outlining how to get the best finish from a stainless steel print. I've seen other methods of metal printing which do give slightly better results by at the expense of a much higher price (I got quoted between £800 and £1500) for one model from several different manufactures!
What are the plans for those wheels? Are you looking to get them cast as a commercial venture?
Whilst blasting will reduce or eliminate the stepped / stratified texture of a 3D print, will it not also tend to round off all the edges and corners, even if you happen to want them to stay sharp?
Hi Atlantic,
I hadn't thought about the effect that sand blasting would have on sharp corners. However maybe a light blasting followed by a spray over with some Halfords filler primer might produce something that can be worked with...
