So the A4s were actually replacing A3s which were being appraised for a permanent switch! I assume then as they returned south in September 1957 that they fixed the fault with the A4s? Will look at my Book of the A4s and see whether it says anything in there.strang steel wrote:
The 1957 Railway Observers say very little, apart from noting the transfer of 60003, 60008, 60010 and 60030 to Grantham, in exchange for 60044, 60103, 60136 and 60139.
It does mention that the first observed working of 60010 from Grantham was on the 0550 ex-Kings Cross on 4th April.
The corresponding Railway Magazines for 1957 say very little also, except to repeat the numbers of the transferred locos, but the June 1957 Trains Illustrated (well, it is a miserable day and SWMBO is away until this evening ) comes up with this:-
"We understand the reason for the change is that the A4s now prove heavier on maintenance even than the A3s, let alone the A1s; in particular, an unexplained tendency of A4s right hand driving axleboxes to overheat is causing concern. Following the transfers, a series of dynamometer car trials was concluded between London and Newcastle with A3s to test their ability to tackle through workings between the two cities."
Ian
