Photos on LNER lines more added 12th June from 1947on
Re: Photos on LNER lines more added 20th March from 1947 on
Edit: irrelevant, see below!
Last edited by S.A.C. Martin on Thu Mar 21, 2013 11:01 am, edited 1 time in total.
Can't argue with that! What a fantastic photograph there too. I never knew there were articulated coaches like that.jwealleans wrote:Post #47 here.
- strang steel
Thanks very much.jwealleans wrote:Post #47 here.
I wonder if an articulated set like that is worth considering as a 4mm project?
John.
A few more added, as usual at:
http://www.flickr.com/photos/davidwf2009/
Grantham and Cambridge this time. Sorry about the quality of some of them.
David
David
You may enjoy my photos which have now moved to flickr from the sadly missed fotopic.
They can be found at: http://www.flickr.com/photos/davidwf2009/
More added today.
Trumpington, March, Bulwell Forest, Wilford Bridge, Peascliffe.
David
David
- strang steel
John.
Re: Photos on LNER lines more added 23rd March from 1947 on
A few more this afternoon - Cambridge and Liverpool St. There may be a few more later on.
David
David
More added today, Nottingham Victoria, Grantham area plus some on the Midland (dare I mention that?).
David
David
The Thane of Fife picture shows a Thompson A2/3, not an A2/2. The full size deflectors and the original Thompson boiler (complete with round dome, rather than banjo dome) can both be seen, along with the flat fronted cab (the A2/2s had the V shaped cabs inherited from the P2s they were rebuilt from).
I think that is likely to be 60500 Edward Thompson, as seen here elsewhere on Flickr, if the number was presumed to be similar to 60505 of Thane of Fife. Certainly has all the correct details (round dome boiler, full deflectors, stovepipe chimney, smokebox numberplate in higher position). The locomotive in your photograph, however, has a shedcode plate without the SC (self cleaning) additional at the bottom.
S.A.C. Martin wrote:The Thane of Fife picture shows a Thompson A2/3, not an A2/2. The full size deflectors and the original Thompson boiler (complete with round dome, rather than banjo dome) can both be seen, along with the flat fronted cab (the A2/2s had the V shaped cabs inherited from the P2s they were rebuilt from).
Many thanks for this.
If it is not 60500 it is possibly 60515 - I just need a photo of each (and others?) around that date.
Somewhere in the albums there must be a photo of the train with 60505, I've picked the wrong image notes without checking properly (again - more haste less speed.
Please do keep letting me know of errors and omissions, I can then amend my notes as well as the online images.
David
More added today at:
as usual.
An emphasis on freight today.
David
as usual.
David
Another score added today.
David
David
Astounding - E1312! I'm looking through my Yeadons and my RCTS volumes for the B1s and I can't find a hint of that livery variation on that particular locomotive. Great find that.
The other one with the light engine B1 and the Cambridge to KX train has an unusual clerestory coach as the third one in - any ideas what the type of that coach is?
The loco looks so clean in the photo, even the cab roof, that I suspect it must have been almost brand new (when it was allocated to Sheffield Darnall from 23/4/48).S.A.C. Martin wrote:Astounding - E1312! I'm looking through my Yeadons and my RCTS volumes for the B1s and I can't find a hint of that livery variation on that particular locomotive. Great find that.
It must have been built just at the time when the numbering system was being sorted out. The LNER numbers seem to stop at 1303, then it is the BR numbering from 61304 according to brdatabase info. So if it was only the 9th built after the LNER numbers were no longer used by North British it may well have had the E prefix to start with.
I've no idea what the coach is, I'm certainly not an expert on LNER coaching stock.
David
