F4s in Hull
STU1964
GER J70 0-6-0T Tram
F4s in Hull
Post by STU1964 »
Can anyone tell me what duties these 2-4-2Ts had in Hull? As far as I know there were only 2 allocated to Dairycoates (7175 and 7184 - later becoming 7171 and 7175 and finally 67171 and 67175).
thanks in advance for any info.
Stu (forum newbie)
65447
Re: F4s in Hull
Post by 65447 »
Reallocated to Hull (Dairycoates) during 1946 to replace withdrawn Worsdell F8s. Used primarily for shunting, but 7175 noted pulling Inspection Saloon in April 1946. All withdrawn in August 1951.
There were 3 - 7175 (renumbered 7171), 7184 (7175) and 7578 (7155) - the duplication by renumbering of '7175' explains the third...
STU1964
GER J70 0-6-0T Tram
Re: F4s in Hull
Post by STU1964 »
65447 wrote:Reallocated to Hull (Dairycoates) during 1946 to replace withdrawn Worsdell F8s. Used primarily for shunting, but 7175 noted pulling Inspection Saloon in April 1946. All withdrawn in August 1951.
Thanks very much for the info. I did wonder about them on inspection saloon duty - good to have it confirmed. One hopes that 7175 was renumbered first or there would have been 2 F4s with the same number.
7mm Mick
Re: F4s in Hull
Post by 7mm Mick »
Hi Stu,
Do you have any photos of the F4's ? Did they carry 'British Railways' on the tank sides at any point ? I only ask as I model the Hull area around 1950 and an F4 would be great to model,
ATB Mick
STU1964
GER J70 0-6-0T Tram
Re: F4s in Hull
Post by STU1964 »
7mm Mick wrote:Hi Stu,
ATB Mick
Hi Mick
Wish I could help - I've got most books about Hull and East Yorks railways and have drawn a blank. I'm planning to model West Parade Jct/Argyle St in MSTS in late 49 - a real mix of LNER, British Railways and early BR logo. An F4 will be on the inspection saloon duty
cheers
Stu
65447
Re: F4s in Hull
Post by 65447 »
7171 (ex-7175) was renumbered 67171 by 27/4/49 during a general repair at Stratford and scrapped 1/8/51;
7175 (ex-7184) was renumbered 67175 also by 27/4/49 during a general repair at Stratford and similarly scrapped 1/8/51;
7155 (ex-7578) was only at Hull briefly, being transferred to Malton on 29/9/46, renumbered 67155 by 15/4/50 during a general repair at Stratford and scrapped 14/8/51.
Above information from Yeadon Volume 39.
As all three were sent down to Stratford for the repairs it would seem reasonable to assume that these three were out-shopped in the same livery as applied to others of the class at around the same time, although not specifically listed as such in Yeadon. Accordingly, 67171 and 67175 probably received unlined black with ‘BRITISH RAILWAYS’ on the tanks and the number on the bunker sides, but with the correct form of Gill Sans 6. See Yeadon p100 lower.
From August 1949 the words were replaced by the Lion and Wheel emblem facing forwards, but still unlined black (only the Autotrain-fitted members of the class were lined out), so 67155 probably received this. See Yeadon p101 lower.
If any photographs do turn up, confirmation or correction of the above would be useful.
7mm Mick
Re: F4s in Hull
Post by 7mm Mick »
65447 wrote:7171 (ex-7175) was renumbered 67171 by 27/4/49 during a general repair at Stratford and scrapped 1/8/51;
Thanks very much for taking the time to post this information, very useful indeed. Like you Stu I have most books on the Hull area and model around the same period and it does seem that the Hull F4's were extremely camera shy, either that or the authors saw fit not to add them. I would like to model one of these at some point as they are unusal to the area and I like the unusal. One on an inspection saloon, that would look lovely, i'll ponder this further,
Cheers Mick
ten ten
Re: F4s in Hull
Post by ten ten »
The Hull inspection saloon was possibly the venerable four wheeler BR number 900270, which survives at Tanfield.
65447
Re: F4s in Hull
Post by 65447 »
ten ten wrote:The Hull inspection saloon was possibly the venerable four wheeler BR number 900270, which survives at Tanfield.
And the F4 hauling it was probably (6)7175, as this was the only one of the Hull trio fitted with steam heating apparatus.
STU1964
GER J70 0-6-0T Tram
Re: F4s in Hull
Post by STU1964 »
Many thanks all for the info. It's been a great help. The Yeadon F4 book is now on my birthday list. I'll keep searching for photos of the Hull locos and update when I find something. In the meantime here's my first pass at an F4 in GMAX. I found some photos of the inspection saloon at Tanfield so will have a go at a virtual model of that too.
regards
Stu
F4 67171 GMAX
F4 67171 GMAX
7mm Mick
Re: F4s in Hull
Post by 7mm Mick »
STU1964 wrote:Many thanks all for the info. It's been a great help. The Yeadon F4 book is now on my birthday list. I'll keep searching for photos of the Hull locos and update when I find something. In the meantime here's my first pass at an F4 in GMAX. I found some photos of the inspection saloon at Tanfield so will have a go at a virtual model of that too.
regards
Stu
Lovely work Stu, I wish I could knock one up in N/S like that :D I'll keep an eye on here see if any photos surface
Cheers Mick
65447
Re: F4s in Hull
Post by 65447 »
regards
Stu
If you can find a copy of Railway Bylines Annual Number 5 that has a most useful feature on the GER 2-4-2Ts, and of course there's the drawings available through the GER Society on-line shop ('Files Emporium'): http://www.gersociety.org.uk/index.php/home/sales
