LNER C2/GNR C1 Atlantics - looking for details?
Hi all,
I'm in the process of constructing a model of the GNR C1 class/LNER C2 class Atlantics for Trainz Railroad Simulator, and I was after a few details that I can't seem to find. Namely, what were the actual frame lengths for the locomotive and tender, and what was the height of the cab roof and tender sides?
Also, the Wikipedia entry on these beautiful locomotives mentions that the "cylinders were no match for the boiler" and that they were "thrashed" - am I correct in understanding that this means the boiler produced more steam than the cylinders could handle?
Any assistance in this would be appreciated.
Regards,
tbdanny
Regards,
tbdanny
- GNSR D40 4-4-0
Re: LNER C2/GNR C1 Atlantics - looking for details?
Don't trust everything on Wikipedia.
ooOOOo-oooo--o-o-----o-o-o-o---------o-o-o-o--------o-o
I presume you have seen this download/file.php?id=7248&mode=view
Website: http://www.mousa.biz
Wikipedia is no more or less trustworthy than any other forum on the internet.LNER Fan 60008 wrote:Don't trust everything on Wikipedia.
Bill,
I did do a search of the forum, for the C1 class Atlantic, but wasn't able to find that image. It's exactly what I need - thank you.
Regards,
tbdanny
Regards,
tbdanny
- GNSR D40 4-4-0
Fair point, I suppose...Bill Bedford wrote:Wikipedia is no more or less trustworthy than any other forum on the internet.LNER Fan 60008 wrote:Don't trust everything on Wikipedia.
I built a coal fired Gauge 1 GNR Class C1 a few years ago and still have some of the basic information. I can be contacted through the moderator.
This depends on your point of view.tbdanny wrote:Hi all,
The Wikipedia entry on these beautiful locomotives mentions that the "cylinders were no match for the boiler" and that they were "thrashed" - am I correct in understanding that this means the boiler produced more steam than the cylinders could handle?
tbdanny
1. The boiler was too big for the cylinder capacity.
2. The cylinders were too small for the boiler capacity.
Depends on your point of view, really. Whatever, they were very impressive machines.
Hi all,
I've got another question regarding this particular prototype. From what I can see in the photos, the rear axle doesn't appear to be mounted on a separate bogey, but is just within the same frame that holds the driving wheels. My question is did this axle have any sort of sideplay, or did it form a rigid wheelbase with the two driving axles? (I.e. a 4-6-0 in terms of wheelbase articulation).
Thanks for the help,
tbdanny
tbdanny
I assume you've already realised Danny, that the downloadable diagram shows the unique second-rebuilt form of No 3279. Its cab was longer than standard, as well as having the curved roof. I can't remember with certainty at present, but the frames may have been lengthened at the rear to suit the cab. Check the bogie dimensions too.......
- Saint Johnstoun
The attached will assist
Basically there was no side-play on the trailing axle.tbdanny wrote:Hi all,
Actually the PO was asking about the C2 Klondikes.Atlantic 3279 wrote:I assume you've already realised Danny, that the downloadable diagram shows the unique second-rebuilt form of No 3279. Its cab was longer than standard, as well as having the curved roof. I can't remember with certainty at present, but the frames may have been lengthened at the rear to suit the cab.
