MikeTrice wrote:
The two vents nearest the camera will be the vents for the toilet cisterns. So what is the third vent for?
Just to muddy the waters I have found a GA for an Open Third which shows a vent to the boiler (the vents are all to the same design). So what boiler is this? This raises another interesting sidetrack, how is the hot water supply provided to the wash basins. I guess steam is passed through a heat exchanger somewhere to heat the water, but this is pure guesswork on my part.
There have been some references to occassions when an end torpedo vent is offset from the usual centre line position. In some cases the water tank has an offset tube through it to provide the airflow from the vent into the toilet compartment. But not always. In a GA for a corridor composite the header tank is smaller allowing air to circulate around it. In this instance the torpedo vent is central but the internal opening is offset.
Mike - how relevant is the diagram of the corridor composite above to D175?
4493 wrote:
Mike/Graham,
I think you have answered your own question here, the third vent is for the water heaters. The heat exchangers are fitted inside the wooden pedestal under each toilet wash basin, the steam supply comes up through the floor. I stand correcting here but I think the earlier compartment stock had a different design heater to the later tourist stock as no roof vent or associated pipework is shown on the toilet drawings.
Marcus
Mike and Marcus, thank you for your contributions to establishing the purpose of the "upside down" U-bends. If I may step back a moment and take stock of what has been written.... let us consider the case for a carriage with a toilet at one end, such as a D114. There is just the one toilet compartment. one water tank, one closet and cistern - the consensus seems to be saying that there should be one vent pipe for that water system. Where is that vent pipe, on the roof, in relation to the toilet bowl?
Assuming that there is one wash basin per toilet compartment, would that basin have hot and cold taps? I presume that there would be no need for a heat exchanger if there was no hot water to the basin.... so when was hot water available for the wash basin?
When a wash basin has hot water, with the heat exchanger under the basin, where is the vent pipe in relation to the wash basin?
And finally, if there is one vent per cistern and one vent per water heater, then one would expect to see four vents on an end-vestibule open carriage rather than the three which appears in Mike's photo (and thank you Mike for posting the referenced photo here). Or maybe there is just one water heater for the two toilets?
regards, Graham
