Line drawing of A4
EHeaps
GNR J52 0-6-0T
Re: Line drawing of A4
Post by EHeaps »
Blackout60800 wrote:The 115A :) Since what I do is not professionial, I'm not keen on spending any money on it so I make do with MS paint.
Have you tried GIMP or paint.net? Theyre both free and although, but I've not used them myself, I've heard many good things about them. From what I gather, paint.net is a simpler easy to use programme whilst GIMP offers very high levels of capability, similar to those of photoshop but is also much more complicated.
Post by 60800 »
I have gimp, but it is very difficult to use.
Artur Gorote
GER J70 0-6-0T Tram
Post by Artur Gorote »
If I understand their blurb correctly, both GIMP and Paint.net are bitmap processors and aren't the right tools for technical or technically oriented drawings. You really do need vector graphics. Wikipedia carries a summary of vector graphics editors:
http://en.wikipedia.org/wiki/Comparison ... cs_editors
Some of these are freeware. Hope this helps.
Best regards
Artur Gorote
RSR Works
Bevice
Post by 60800 »
Thanks, there may be another new A4 appearing soon :)
Artur Gorote
GER J70 0-6-0T Tram
Latest draft of A4-styled 455A.
Just finished a draft of the A4-styled 455A. It needs more work on the tender and the lettering.
Post by 60800 »
I like it :) but, there are a few changes I would make:
For the scale of the loco, the chimney is too big overall and too tall.
The handrail should extend into the black portion of the smokebox.
The valances need to have clear panel lines/gaps.
The smokebox casing hangs too far over the leading bogies too.
Provision needs to be made in the casing and centre of the valances for access hatches
Personally, I would streamline the tender too.
Artur Gorote
GER J70 0-6-0T Tram
Thank you for comments, Blackout.
The chimney of the 455A is a quadruple Lempor, which takes up more space than a twin Kylchap. The chimney cowling is the same length as the exposed chimney of the 455A and extends to the top of the loading gauge like the cab roof. I have raised the top line of the streamlined casing behind the chimney to reduce the contrast in height.
That I will see to.
That too.
I have arranged the front of the streamlined casing to be flush with the front edge of the buffer beam.
> Provision needs to be made in the casing and centre of the valances for access hatches.
These I'll see to as well.
