60532 Blue Peter - current situation?
Re: 60532 Blue Peter - current situation?
Possibly in an attempt to lift smoke clear? An A4 has the same slight dip in the boiler cladding just behind the chimney.
Post by 60800 »
I thought it was either to do with smoke lifting or the loading gauge myself.
Back on to the restoration possibilities, are there any major parts like cylinders etc that need replacing, or is it just 'the usual' that's needed?
The present quotation that I have come across is £500,000 to return her to mainline standard.
Blink Bonny
Post by Blink Bonny »
It could also be that some twonk with very big boots has dented it at some time! :lol:
majormagna
H&BR Q10 0-8-0
Post by majormagna »
Blink Bonny wrote:It could also be that some twonk with very big boots has dented it at some time! :lol:
I'm actually leaning towards this answer, as Tornados dome doesn't sport the same 'dent', and it is much less apparent when looking at photos of Blue Peter in BR Dark Green; and there doesn't seem to be the dent at all on other photos of A2s.
EDIT: Upon more thought, perhaps the dome casing is simply losing a bit of structural integrity, causing it to sag a little in the middle?
Moors Bound
Postman Prat
Post by Postman Prat »
Re Blue Peter at Barrow Hill, I can confirm it was very 'healthy' as in the attached photo. I promise no Digital magic has taken place!!!
PP
Post by 60800 »
I'm afraid that's rather hard to believe, although it would be wonderful :mrgreen:
But.......... am I seeing things here, or is there really steam coming from her chimney? :shock:
Postman Prat
Hi Blackout
I give you my word of honour as a Prat(!!!) that nothing digital, or darkroom manipulation, took place
If no-one else does so, I'll put you out of your misery before xmas, if I get time
PP
Post by 60800 »
How did they fire her up then?
It seems quite reckless to me, unless they somehow had the safety valves wide open so that no pressure built up.
Blink Bonny
At a guess the boiler was empty with rags burning in the grate.
As for your piccie of 532 working hard? There wouldn't happened to have been a certain A1 hiding behind her, would there?
richard
Post by richard »
Yes oily rags on the grate is the usual trick. They even did that to Locomotion No.1 in 1925...
majormagna
H&BR Q10 0-8-0
Blink Bonny wrote:There wouldn't happened to have been a certain A1 hiding behind her, would there?
I can pretty much assure you that there is another Pacific hiding behind Blue Peter...
Moors Bound
Postman Prat
Hi BB
Never could stand smartarses!!
Right on both counts!!!
Happy Xmas and Properous New Year to us all
Ian
PP
Blink Bonny
:wink:
markindurham
H&BR Q10 0-8-0
Post by markindurham »
I believe that the middle cylinder is in need of replacement. I too would love to see 60532 back on the main line, but it's not looking good at present, is it? At least she's being looked after at BH
