LNER A4 liveries
52D
Re: LNER A4 liveries
Post by 52D »
Graham in 1946 the LNER carried out a major renumbering to put all locomotives including the A4s in an easily recognisable sequence, prior to this some were also renamed from traditional bird names to names reflecting the then current directors of the LNER. The valances were indeed removed to aid maintenance under wartime conditions.
There are plenty of people on this site who can give chapter and verse on the liveries carried. I myself am amazed at the variety and also the number of changes between locos.
I would suggest careful research and asking questions if unsure.
Post by 60800 »
It's probably fair for me to say that considerable changes have been made to the A4's.
Here's an example of Silver Link;
[The extension bmp has been deactivated and can no longer be displayed.]
Compared to the old version;
Please click on the links, as they don't show up too well on this page.
Blink Bonny
Post by Blink Bonny »
You've nearly got the shape at the front end right with them! Well done.
Until I saw a picture of the press run of the Silver Jubilee, I never "got" the Streamliners. I do now!
Post by 60800 »
Thanks BB :) , I think the cab area still need a lot of work though and the trailing axle on the leading bogie might need to edge forward a bit too.
Graeme Leary
Post by Graeme Leary »
Many thanks 52D - as you suggesr; 'asking a question'. So, would there have been any A4s running PRE WW2 WITHOUT valances?
My 'pedantry' is that I have an A4 model (Golden Plover in BR green livery with early crest) without valances but as I want to be as accurate as possible to LNER livery, names and numbers etc, (ie pre Nationalisation) I would rather sell this model and get another A4 WITH valances to repaint, number etc.
Also, in what year did the double chimneys start to appear? Was this a post war improvement or were some fitted before the war?
And finally, were any pre-war A4s painted in any of the GREENS used by LNER and if so could you name and number some examples for me (and again, would they have had valances, single chimneys - and what type of tender?
Many thanks in anticipation.
52D wrote:Graham in 1946 the LNER carried out a major renumbering to put all locomotives including the A4s in an easily recognisable sequence, prior to this some were also renamed from traditional bird names to names reflecting the then current directors of the LNER. The valances were indeed removed to aid maintenance under wartime conditions.
2002EarlMarischal
Post by 2002EarlMarischal »
None of the A4s ran pre-war without valences.
Double chimneys were fitted new in 1938 to garter blue A4s 4468 Mallard, 4901 Capercaillie, Seagull and Peregrine. Others did not receive them until 1957 onwards.
Apple green A4s were 4482, 3, 4, 5, 6, 7, 93, 4, 5 though the front end treatment differed. All the apple green A4s had valences and single chimneys and corridor tenders. The livery did not last long before garter blue was standardised.
I suggest you try to get hold or sight of RCTS Locomotives of the LNER Part 2A which gives all this information and much, much more.
52D
Post by 52D »
I concur with EMs suggestion, but if you get stuck on any detail ask here.
Marvin
Post by Marvin »
I'm going to do what I did last time a question like this was asked, and recommend reading this webpage for details of A4 liveries, name changes etc:
http://www.sirnigelgresley.org.uk/a4name/a4names.html
kimballthurlow
Post by kimballthurlow »
Hi all,
I have a project part finished, which is to repaint 8 of A4 models with the various paint schemes used in their lifetime.
I have chosen No. 4487 Sea Eagle (or 60028 Walter K Wigham in BR days), as this is one of the few A4s to have undergone repainting in the 8 different paint schemes. (This does not include the early grey/silver paint applied only to the Silver.... series of A4s.)
I am partial to models made of metal, so I have chosen Hornby Dublo 3 rail as the basis for my project.
So far, I have two pre-war machines in green and garter blue with valances (both look magnificent), and two-post war machines in blue lined white, and BR green.
To be honest I am not sure that I will get around to doing the wartime black, but at some time I hope to have the post-war garter blue No. 28, and the early nationalisation purple scheme.
As a reference, I have used a book published in 2005 by Ian Allen entitled Locomotives in Detail - Gresley 4-6-2 A4 Class. It has a comprehensive coverage of tenders, equipment, liveries and name changes, and dates thereof.
I am surprised and delighted that so much old Hornby Dublo stuf is around, and still runs "out of the box" so to speak. I admit, it does not run as finely as the modern stuff, but I understand and appreciate the difference.
regards
kimball
Post by 60800 »
Latest version, 4498 in wartime black. Please notify me of any mistakes :)
As always, please click on the thumbnail for the larger and clearer detailed version.
EDIT: Since posting the piston diameter has been made thinner.
From RCTS
Black livery with shaded lettering in full LNER as repainted Black prior to 09/42. Not aware of numberplate being Red.
Post by 60800 »
Shaded letters and numbers will have to be a sacrifice I'm afraid. I'm rather limited with MS paint.
I'll change the nameplate to the usual black backed version.
When you say full LNER, do you mean all four letters on the tender, as opposed to just NE?
Post by 60800 »
I've also just fixed something else which I kept forgetting about, which is the dip in the cab roof. That has now been added and the tender has been lowered along the top.
These current changes are on 60009, and will be added to 4498 and 2509 in due course.
Other locos to be done to complete the liveries list will be:
Woodcock in photographic grey
Silver Link with nameplates and no parabolic curve
Kingfisher in Br blue
Dominion of Canada in coronation Livery
Mallard in Garter blue
Merlin in experimental purple
and an apple green A4
Yes LNER :shock:
Post by 60800 »
60009 and 4498
New features:
Cab roof with dip
New tender front and forward bulkhead
Lowered tender roof and new corridor cap
Number plate on 60009
Re-designed cab interior and exterior
Smaller diameter pistons
Smaller cyclinders
Trailing truck pushed forward slightly
errr.... forgot about 4498's nameplate :oops:
