Guard's Brake Coach door handle orientation
Autocar Publicity
NER C7 4-4-2
Re: Guard's Brake Coach door handle orientation
Post by Autocar Publicity »
Shouldn't that picture have been posted in my thread on heavily 'weathered' vehicles in the model railway section?
Ironically, I've been working today on a set of luggage double doors that were sticking, but they were on a Mark One, so different mechanism...
StoneRoad
LNER J39 0-6-0
Post by StoneRoad »
Ripe for restoration.......let me at it....
Ok, What and where? just for information.......(Please can Testerol PM me the answer)
Stoneroad
Saluton. mi estas fervojistino, kaj vi?
visit http://www.ipernity.com/doc/312383/album
to see what has been done! Perhaps we can do something for you?
Trestrol
Post by Trestrol »
[quote="Autocar Publicity"]Shouldn't that picture have been posted in my thread on heavily 'weathered' vehicles in the model railway section?
If you want heavilly weathered try this!
Autocar Publicity
NER C7 4-4-2
To quote Stephen Middleton, "Hmm, I've tackled worse..." !
That does look like a challenge though.
StoneRoad
LNER J39 0-6-0
Post by StoneRoad »
Right up my street! :lol:
Needs a fair bit of work, so some good fundraising required......
gdb
Post by gdb »
Mention is made earlier in this thread of the door locking mechanism for the right hand leaf of each pair of luggage doors... the rods and cam can be seen in this photograph from the web site of the restoration of D114 carriage no. 3669, see:-
http://www.ecolne.free-online.co.uk/tra ... 20Door.htm
regards, Graham Beare
Bryan
Post by Bryan »
The guards door handle.
Was there a Left hand and a Right hand version?
Or could they be inverted?
I think I have 2 left handers and need a right otherwise.
65447
Post by 65447 »
Bryan wrote:The guards door handle.
Bryan, as I posted previously:
65447 wrote:Just to round off the information, Guard's doors on the 'offside', that is with the Brake Compartment to the left when viewed side on, normally have doors that are the opposite hand (hinged on the left) but the door handle still points upwards.
That suggests, if your handles are not dead straight but have any form of curve or other shape that is not symmetrical, they must also be handed.
gdb
Post by gdb »
In pursuit of some other question about the D175 carriages I have been sent the photograph below, courtesy of Richard Carr. This image shows the "other" side of the guard's compartment to the photo with which Mike Trice started this thread. This maybe my imagination.... however the door handles look assymetric and hence are handed.
As an aside to the orignal theme of this thread, can anyone identify the purpose of the lever/pipe/thing which is projecting below the footboard to the luggage doors?
D175 no. 24068 on SVR - photo by and courtesy of Rochard Carr
regards, Graham
Post by Dave »
Hi Graham,
I think it is a water filler pipe for the water tank to the toilet. If you look on the roof above you can see the tank overflow and filler cap just above and to the right.
gdb
Post by gdb »
Dave wrote:Hi Graham,
Seems a reasonable suggestion... in which case there ought to be another on the other side of the carriage.
regards, Graham
65447
Post by 65447 »
gdb wrote:Seems a reasonable suggestion... in which case there ought to be another on the other side of the carriage.
"Attention having been drawn to the time taken to fill carriage roof tanks because men had to climb on the roof to insert the filling hose, a simple arrangement for performing the operation from the ballast was devised consisting of pipes running from the roof tanks to nozzles on either side of the vehicle at headstock level. The staff had merely to place their rubber filling hose on the nozzle and when the tank was full water ran out from the nozzle on the opposite side of the coach. This arrangement was instrumental in enabling the operating department to cut down station times at York, Newcastle and other places at which tank filling was carried out during the journey."
Norman Newsome, The Development of LNER Carriage and Wagon Design, 1923 - 1941. Paper to Inst Loco E 1948
So the answer is yes.
gdb
Post by gdb »
Ah... the light switch might well have been turned on! Am I to infer from the comment "when the tank was full water ran out from the nozzle on the opposite side of the coach" (quote from Newsome) that the water filler pipes and the water tank were a closed system? And that the "overflow" pipes on the roof are not to provide an overflow outlet for excess water when the water tank has become full?
regards, Graham
Post by Dave »
Hi
As I am new to this forum lark I hope I have uploaded these 2 photos.
1 showes the other side of the brake and you can see the water filler, and 2 shows a standard LNER filler pipe.
You can see they all match.
4493
Post by 4493 »
Gents,
The pipe on the roof is actually the toilet cistern vent pipe (as already mentioned the water tank overflows through the opposite filler pipe).
